That’s probably the best option, especially since none of the other gables will have a matching detail.And, I prefer it like this with NO timber detail.
Dude. I friggin love thatAll finished with the chill tub!![]()
Mike.
_______________
[emoji631] [emoji631]
Sent from my E6810 using Tapatalk
Nice. Dam look at all that space.All shimmed, shaved, and blocked. Started putting down subfloor after lunch.![]()
Looks like a 0 barrier home.Started framing today.![]()
Sounds like time to break out the angle grinder.And I couldn't cut the mesh with tin snips, just too thick for my snips. So I had to cut each and every wire with nippers. 4 foot strips 14" wide. It's like 96 cuts per length times two sides times 12 strips.
Yup. A little slower to frame the deck but it's nice to not have any steps anywhere. Not an old couple but they have older family they want to make sure have easy access when they come over.Looks like a 0 barrier home.
Everyone says that. The mesh is to delicate. It's not welded at the joints, just little curves that intersect and hold it in place, it's more of a weave. Plus I don't know what the heat would do to the brass plating on the steel wire. I only have to cut it to length now. And after all that cutting I've developed a system to do it pretty quick.Sounds like time to break out the angle grinder.
How was the reverse brickledge for you? The last 0 barrier home we did, a couple months ago, was junk. The concrete guys used foam in the forms to create the ledge and it floated all over. We spent a few hours cutting it level and fitting the ledger. Did you skip the rim board on the ledger? A lot of floor engineers spec the rim, or call for bridging even though the floor sheething is fastened to the foundation plate a few inches away.Yup. A little slower to frame the deck but it's nice to not have any steps anywhere. Not an old couple but they have older family they want to make sure have easy access when they come over.
I think big guys are that way on purpose so they don't have to do the things us little guys do. :laughing:I'm the tallest guy on the crew.
I'm also the skinniest. :sad:
