Hello guys,
What is the best caulk for sidings? What do you think of dap dynaflex 230 white?
Thanks
Thanks
230 is designed for interior use, it is absolutely wrong for exterior siding. Quad 4 is very strong, white or grey have the best consistency (IMHO) and are easily paintable.Hello guys,
Thanks
QUAD is great but a pain in the ass to work.
Not according to DAP, who should know. The first line on their web page:230 is designed for interior use
I order Big Stretch by the case.
Mike.
___
[emoji631] [emoji631]
Last time I used colored QUAD, it bubbled.I have use Side Winder only in white though. Seem like it comes out of the gun a little hard. For siding I use the color match Quad or Quad Max.
I don't remember the last time ever blow a tube out with Quad. Lexell is ok , but it is only clear and white.I only use caulk in plastic tubes. Isn't regular quad in paperbtubes still?
Same reason I stopped using the regular geocel. Ibwould blow three out of four tubes. Lexell works better anyway.
I rarely ever tool Quad. Think it looks better not , IMO.What is the difference between quad and quad max? I only use quad max these days.
It seems to tool better than the old quad.
Anybody still using vulkem? That stuff sucked.
Yes and I have also had that issue with Vulkem. Though, more so with the Vulkem than Quad. I asked about caulk bubbling on JLC maybe 14 years ago, but nobody seemed to have a definitive answer. So it just remains an unsolved mystery for me.Last time I used colored QUAD, it bubbled.
Anyone else seen this?
TYYes and I have also had that issue with Vulkem. Though, more so with the Vulkem than Quad. I asked about caulk bubbling on JLC maybe 14 years ago, but nobody seemed to have a definitive answer. So it just remains an unsolved mystery for me.
I have it on my own house for 11 years not one single joint has failed must be user error.Whatever you do don't ever use quad. Over a couple years quad gets hard cracks and peels away from the joint material and doesn't work. It breaks down and I've had nothing but problems with it. The best I've found is get the color that you need and use dow790 or 795 for exterior work it is extremely durable. This is a professional caulk and you can order online easily. It's uses are endless and they also make structural caulk, interior, exterior what ever type of caulking your doing they've got it.
