21 - 35 of 35 Posts
It is a great little saw. I just used it yesterday for cutting door jambs. I have also used it for cutting out flooring under toe kicks. It's really a nice saw for the money ($83 @ Amazon). Reversible blade feature kicks ass! Don't be suckered by the miter kit; it's worthless.
My only complaints are, doesn't come with a case (or bag) and if you hit a nail or anything metal with the wood blades, they're done. Make sure to have replacement blades handy or know where to get them.
Gramps bought that Bosche saw pictured on page 1...we used it once and it then took refuge under the seat of the truck never to be used again. The fine tooth blades make for a nice clean cut, but pack a lunch as it takes forever!! Luickly the truck got broken into and the tool got stolen so somebody else is hopefully getting some sort of usage out of it, but i imagine whomever took it kicked their own azz for taking it...IMO it's one of those tools that sounds good in theory, but the reality is it sucks LOL!!
The multi tool with it's fine blade takes forever and will often burn out, esspecially once you get the blade hot and then start hitting nails.
I would be interested in the toekick saws, since the circular saw would produce the fastest cuts vs all these ocilating/reciprocating saws other's mention...so in the big picture, there just is no real "easy way" to do what your describing, it sucks pure and simple LOL!!
Would it loose against a fine cut handsaw? or Japanese pull saw?
I'm still saving for my Multimaster...and systainer insert.
The japanese saws actually have a more agressive tooth to them vs this Bosche twin blade reciprocating saw, so IF you could muscle it, the japanese saw would out perform the bosche AND get closer to what your trying to cut to boot.
I'd use my Hilti 36V cordless sawzall to cut plywood under a bathtub. Put a demolition blade in backwards, bend the blade a little, and you can flush cut fast with it. I've used toe-kick saws and the Fein Tool, they have their places, but they are slow. I've never used the Bosch flush cut saw, and I've never seen anyone use it either. So I would just assume they are not that great.
Another warning with the toe-kick saw, it's real easy for the top of the blade to scrape and mark up whatever you're cutting. If you're using it under a cabinet it's not that big of a deal if you make a mistake. But with anything visible, you should avoid it.
My Two Cents
I know that the Fein Multimaster would do the job...but it would take forever. That toe kick saw looks pretty awesome but I have never seen or used one. I guess I am behind the times...still using the old sawzall for such jobs.
Or use a 4" grinder with a wood blade. Cost $10.00 and a 40-75 grinder.
I have never done that because I envisioned it being potentially more dangerous than most other options....
Last year a friend of mine (not in the trade) decided he was going to remodel his kitchen...Towards the end of the project he was using a 4 inch grinder with a wood trim blade, and it kicked on him just about taking his forearm completely off. He dropped the grinder and it land on his thigh , cutting his femoral artery....
He was medivaced and his life was saved , but his arm is now partially disabled....
I know all of our tools are potentially dangerous , but that set up is
IMO a bad idea.
21 - 35 of 35 Posts
