Yeah, Dom-mas, I was going to say that I've done quite a few of the temporary t-posts, or doubled 2x's, bearing directly on some type of 2x cribbing sitting on top of a larger piece of 3/4" plywood, if (and I do emphasis the word "if") there isn't much of a load. In fact, on light enough loads, I've even done this on just a piece of 3/4 plywood large enough to evenly distribute the load.
Then again, the entire shoring you're proposing (or anytime any of us do this) depends entirely on the loads imposed on the column (posts), the length of the columns, even the species of wood used for the columns.
In reality, the ultimate stresses that would actually cause failure in the column is variable due not only to live/dead loads placed on it, but also due to defects, size and location of knots, lumber density, and even moisture content. If you're interested, there is a formula we can use to insure a safety factor to let us know that the loads placed on any column/post will result in it buckling so badly it could fail under those specific conditions. I usually will implement the calculation of all this if I am questioning the situation at all. It helps me to better design my posts, or spacing, footers, etc, in order to prevent a disaster. But suffice it to say (and as already mentioned) that the t-post will resist buckling more so that if the same two pieces of dimensional lumber were tied together with the grain running parallel.
