I made one of these out of solid cherry a week ago and got it stained and finished. Tried to make it a full fill finish and you could still see the joints. It was kinda unstable because of the massive difference between the outside and inside grain expansion and contraction. While I was finishing it I thought I got it under control be low and behold it reared it's ugly head and actually cracked the finish in the inner center.
So I realized I had some self stick cherry plywood from days past and thought I might be able to make it with veneer. I did a test and the self stick had weakened and when I put it on either raw MFD or a surface with a finish I could pull it off too easily. Remembered a trick and I got out the Hamilton Iron and stuck some on raw MDF and applied heat, then rolled it out with a "J" roller and let it cool. It ripped the surface of the MDF off so good enough.
I used the track saw to cut my flitches to shape. I did cathedral grain on the two opposite horizontal triangles and then did straight grain on the next and kept alternating. Last pcs are always the challenge as they need to be perfect. Got the 1st one on the 1st try. The 2nd one took 3 tries. But it was the same pc and I just adjusted the angle.
MIdway, about to put 4 pcs on which would be the 2nd to last round.
Here it is completed. The centers didn't match perfect, but after I stained it you couldn't even tell.
I think this one looks nicer than the solid wood one because of the alternating grain. I couldn't do that with the solid wood I had.
