3 reading
801K views 12K replies 233 participants last post by  tjbnwi
Previous Threads.
Part I
Part II
#1,610 ·
The OP didnt go through...
Small remodel, took out the bearing walls in the kitchen and put in a large engineered I-beam with footings. New kitchen, new floors, modified framing for elevator, barn wood accents and paint. Created bar room upstairs
Sent from my SM-N970U using Tapatalk
#1,619 · (Edited)
#1,629 ·
I dont know your approach but I take cell phone pic's then email them to myself to archive. When I do that I get an opportunity to resize the image from phone to email. small medium large (as is). Dropping it down to medium allows me to attach them here. Otherwise its too big
Im sure theres an easier way I dont know but that what I do
#1,631 ·
I use a Mac. The way I post pictures;
Go to Photos, select pictures
File-Export--it will show the number of photos selected
Select quality and size---I use high and large
Click Export
If you haven't created a fold yet--click New Folder, my folder for this forum is CT
Click Export.
Once the photos are exported I;
Click Go Advanced
Manage attachments
Choose file
I choose the photo I want
Click choose
Add a couple of more if need be
Click upload
I find I can attach as many as 5, you need to upload the first three to do the other 2.
I've aslso found if the OS has auto updated, I need to restart the Mac to get the attachment funtion to work on CT.
Tom
#1,633 ·
I've been really busy, but I'm still around. Working on this raw water treatment plant for Canfor. Not many photos being taken recently, but that sloped concrete form was quite a fun one for me. I'm going for a crane basket ride in the next week or so, I'll grab an up to date picture of the whole spread then.
Sent from my SM-G973W using Tapatalk
#1,636 ·
Thanks guys. I've been mostly on the "smaller" parts of the build, concrete free forming and suspended slabs. The big stuff is all aluma beam gang panels ranging up to 30' tall.
Project is around $27-30m if I recall correctly. Easily paid off from the roughly $7m in savings per year from bleach during the spring runoff.
#1,637 ·
Showed up to a Habitat for Humanity job we were hired to set the trusses on and roof. Volunteers had already installed the garage trusses, then realized the garage foundation had been set one row of blocks too short, so all the trusses had to come off so we could throw some knee walls on top of the garage to bring the fascia all in line with the rest of the house.
So we beefed up the lumber tying them altogether, wrapped a couple straps around them, and lifted the entire roof off the garage. Set it down next to the garage, threw on the walls, and went about setting the roof structure back on. Skytrack hit a big rut in the yard that was covered over by snow, took a hard bounce, and the whole damn thing fell apart.
Pulled the huge mess apart. Only one truss was damaged. Had to mend it according to the engineer's specs.
Lesson learned? One at a time, or a lot more beefy lumber. All of us were standing WELL clear of the garage so no real harm long run, except we looked like morons for about an hour.
Sent from my SM-G973U1 using Tapatalk
#1,641 ·
:laughing: Habitat House ... no good deed goes unpunished :jester:
Glad no one was hurt and not critiquing the hows and whys of what y'all did. Gotta get after it and give it a whirl to get it done with what you got...
Good use for lifting spreaders? Might have distributed the forces-stresses from the bounce more evenly. Possibly not pulling hard on the center racking/stressing everything enough to fall apart, during the bounce.
#1,642 ·
Made a small countertop for myself. I have a 19" cabinet to the left of my stove that needed a countertop refresh. All of them in my kitchen are MDF with clear coats. I did it as an experiment and they last about 3 years before water penetration. The one by the stove gets hot oil penetration. So if the finish gets damaged I can just refinish the wood top.
Made from soft maple. I cut 1 1/2" strips and glued them up so the countertop is 1 1/2" thick. Coated it with a 2K poly.
#1,644 ·
It's cheap. Make a kitchens worth of countertops for about 100 bux and another 100 for finish and a days work, mostly waiting for finish to dry.
I'll see if I go farther. I only have an 8' sink countertop and a 47" x 59" peninsula. That'd be a big chunk of maple.
#1,645 ·
And the tiny countertop is installed.
#1,651 ·
It was brutal. Took me 15 minutes to take the old one off and put the new one on. I had to drill 2 new holes for the screws to hold it down :whistling
#1,649 ·
No scribing and the sanding wasn't that bad. 80 grit and 120 grit. :whistling
#1,653 ·
I have it switched from your house.
