That's awesome
Thanks.Crazy cool man
I'll be in touch....the wife wants me to build a hidden roomThanks.
Swinging in is easy, swinging out not so much.
Hope to get them installed this week.
Tom
That’s what it means.Not sure what that means. But it has an switch in it that detects to high of a water level in the pump container which is connected to the thermostat. If the water in the pump gets to high indicating that the pump has failed or there is a clog in the line the overflow switch will shut down the furnace so it won't produce anymore condensate.
It'll work great if I connect it, which I haven't yet.
The original spring had 9 full winds in it.First torsion spring replacement. Wish me luck. I'll try not to do anything stupid.
View attachment 524326 View attachment 524328
From my days in the garage door business, a general rule of thumb is 1 full wind for every foot of door height for the typical metal sectional door.First torsion spring replacement. Wish me luck. I'll try not to do anything stupid.
Don't put your pecker in there.First torsion spring replacement. Wish me luck. I'll try not to do anything stupid.
Do something stupid, you'll get more eyeballs....First torsion spring replacement. Wish me luck. I'll try not to do anything stupid.
Fwiw, be careful. As I’ve stated here before, saw an experienced service guy get his index & middle finger cut offFirst torsion spring replacement. Wish me luck. I'll try not to do anything stupid.
Thanks for the encouragement, I'm trying to be. I've heard a lot of horror stories. As for your story, did he get his fingers smashed in the winding bars?Fwiw, be careful. As I’ve stated here before, saw an experienced service guy get his index & middle finger cut off
Mike
Set the cables on the drums, hand tension drums, snug drum to shaft, use a pipe wrench and a rope to keep tension on cables by tying the wrench to the vertical rail. This makes it easier for the first few times you have to tension springs.
Make sure you have the winding bar is socketed well before you let it set to the wall to tighten the cup screws.
Tom
Thanks for the tips, that lines up with the advice I got from the guy I bought the spring from.From my days in the garage door business, a general rule of thumb is 1 full wind for every foot of door height for the typical metal sectional door.
Mike.
___
[emoji631] [emoji631]
Yeah, no.Do something stupid, you'll get more eyeballs....
Before you tighten the cup to the drive shaft, tap the winding bar towards the drum, this puts a little space between the coils.Thanks for the tips, that lines up with the advice I got from the guy I bought the spring from.
Yeah, no.
Don’t know. All I remember was 2 fingers on the floor & lots of bloodAs for your story, did he get his fingers smashed in the winding bars?
I missed itLooking good Mike. Your camera angle in that second picture was almost good enough to hide that power plane laying on the concrete behind the bucket. Hopefully rrk doesn't see that, he might have another stroke.
