Wood Between Siding and Brick
14K views 9 replies 5 participants last post by  sgrprince
I'm currently painting a house that has brick on the lower half of some exterior walls, and there's a thin strip of wood (maybe masons have a term for it) between the siding and the brick that looks like it was painted and caulked when the house was built, but that paint has since flaked off and the wood is disintegrating, which allows stuff to get behind the brick. How would I go about replacing that piece of wood (or is calling a mason the better choice)?
#2 ·
Water table? Your mason might have removed headers or rollock bricks, might be a easier to remove it on top depending on exterior finish on top of trim ,Is it stucco?
#5 ·
The problem could be that those top header bricks are level ,that allows water to run inside and create rot and water damange inside the house.Big No No! Those brick need to be relaid at min 1/4'' pitch away from the veneer. You could be doing some serious work.My advice is tearing out headers & top siding .Replace the watertable(wood trim) & raising it up 3/8'' . Check the waterproof backing too.
#6 · (Edited)
what this was is a reciver for the brick rolock.it was more than likely made of pine or some other soft wood and that is the reason is is falling apart.you should be able to remove it and replace it with redwood or some treated lumber and repaint it and recaulk,with no need for a mason.
posted this before before subia's post was up.i agree 100% if there is no pitch away from the house,this problem will continue and only get worse.i was called out on a house where two windows were leaking,from the sill.i discovered that the brick sill actually sloped back into the house.it was a quick fix,and saved the homeowner alot of problems down the road.
#7 ·
The top bricks actually are at a slight slope, sorry I didn't draw that. The piece of wood looks like it's slightly thicker behind the siding, and was placed there before the siding was installed, which means it probably can't be removed without removing the siding (or just wrecking the siding). Does my replacement piece need to be a wedge shape like the original, or will a flat piece be ok? If it needs to be a wedge, would a masonry supply place have a replacement, or is this something that I would need to make myself?
#9 ·
Kevin's Fix
saw sall out the woodwater table. Have a piece of cedar or redwood sill milled about 12-14 degrees [same pitch as window sill] Also there needs
to be a drip grove dadooed in W/table. On the west coast this stock is available in our lumber yards, [w/o groove]. Stock should be 1 1/2" thick.
Just look at the detail on an OLD wood window.Yes, You need flashing! At a min use pollyurathane calk. It's all i use. It's the caulking used on Hi risers. THE BEST. I have a large shop ,woodwork and welding. We could run this for You in a heartbeat. Any REAL carp can ,find one. It's getting harder ,all the time to . Good luck!
