I had a mix up on a window order and the windows are the exact same size as the rough opening. Is there any tricks to make them work
Add sawzall, chisels and skilsaw, belt sanders with real aggressive beltsWarnerConstInc. said:power planer, nail set/cats paw, extra sets of blades.
No, even on the width, even if your lube 'er up and slam 'er home.... there will be problems down the road when the window or opening expands even a tiny bit. The phone will be ringing off the hook because the windows won't open. Or gosh forbid.... won't close now that it's 95 degrees in the shade and their A/C is running 24/7 because they can't close their windows.I'd have no problem with lube and a mallet on the width
My Skilsaw only goes 2 1/2" deep:blink:and what about the top of the trimmer, do you overcut into the header:whistling isn't the wall 3 1/2" thick:blink: I'd pull em off and run in through a table saw but that's just me:laughing: I'm likein clean on my old ageIf they are vinyl, just take your skilsaw, trim the top and sides of the openings to what you need, install windows and your done. .
