Window Header question ????
18K views 15 replies 8 participants last post by  whaler
a siding customer wants a window ireplaced with a larger window. obviously she now needs a larger opening. the window is 32 x 50. she wants it now to be 36 x 52. what size header you guys recommend? 2-2x 6's with half inch in middle or2- 2 x 8's?
#13 ·
Dont know about ya'll, but here in alabama we use the 2003 International Building Code. and header under 5', only have to use one jack stud. Therefore, the header will be 3" larger than the rough opening. Over 5', use two jack studs. Load bearing wall or now, we always use 2x10's with 2x4 on top (Header measures 11", duh).
If its a long window, use engineered beams (LVL's)... metal is too expensive unless wood wont work.
#14 ·
Do yourself a favor measure the head space over all the other doors and windows inside. Its likely at least 12". So instead of guessing proper size and then putting little cripple studs in the remaining space just put in a 2 (2x12) Unless that encroaches on your space for the window it will be completely over kill. In case someone adds onto that split level later it will be fine. FYI the code book makes a suggestion based on what it supports above so when the size you need takes up too much space you can then go to steel to increase strenght on slimmer sizes. And always leave those wall plates in!
#16 ·
when talking about windows and doors, state the width first than the height, codaman brought up the most important point= keep window heads the same height. stuff whatever header fits to make it happen. my guess 2x10/w cap.
