I've been taught when framing a deck to put whatever crown in the lumber down unless its a radical crown then cut one surface straight and put the straight cut up. Is that what you all do it?
N.Pattie
N.Pattie
The only time I've ever seen crown down is when there is a cantilever over 2'. Typically, crown goes up otherwise you're building in a pre-existing sag in the joists. Gravity will take some, if not all, of the crown out when the weight of the decking is added.I've been taught when framing a deck to put whatever crown in the lumber down unless its a radical crown then cut one surface straight and put the straight cut up. Is that what you all do it?
N.Pattie
Seriously, I've been on projects that had roof load and second floor load on 28" cantilevers. It was common practice to crown upside down in that scenario.Unless this is some kind of a jersey joke the crown always goes up. J.
I've never built one with the crowns up, but as all of us know every once in a while someone puts one in with the crown up.Crown up.
Have you been back to look at
your decks later on?
Don't use really bad humped up lumber for the joists
Crown up, use a power planer on the ones that show.
If you crown down just how do you cut out the serious ones??? That would be like trying to cut out a hole.
I am not understanding how 12'' on center makes it worst. J.
