I'm going to be finishing a basement w/ hardwood for a spec house I'm building. I'm putting down the underlayment shortly and will be installing the hardwood at a later point due to scheduling.
Here is what I was thinking for under the hardwood planks, over the slab (I don't do flooring often, and when I do it's typically not over concrete) :
6 mil poly over slab, overlapped and taped (Roberts underlayment tape, unless someone has a better suggestion).
3/4 ground contact PT plywood (ideally not KDAT due to cost, see below on my reasoning). Will be installed floating.
A few questions:
* I was going to do 6 mil poly, but, has anyone had any luck/thoughts on 15lb felt paper?
* For the plywood I don't want to spend the extra money for KDAT unless I have to. I was thinking about doing PT since I have a month or two until the actual hardwood is installed and I can setup some blowers to let it dry out for a while. I'll moisture test before installing the hardwood. Anyone else have any luck doing this, or do they just use KDAT plywood?
* Other systems/suggestions instead? I've seen other systems such as using sleepers or not doing it as a floating underlayment, but.. doesn't seem worth it as the basement is dry, and it's new construction.
Thanks!
A few questions:
Thanks!
