This is a little tough to explain, but I'll give it a shot. I recently did some work on a restaurant that has an enclosed patio. However it was originally built as an open air, half covered space. When they enclosed it, they roofed the rest of it by installing the new roof under the old roof. The new portion goes back under the old portion about 4'.
For whatever reason, they didn't block off the 18 - 24" gap between the old and new. They are putting in mini-splits so I was hired to block off the opening. There's no way to make the room air tight, they just wanted the wind stopped and leaves from blowing in. I finished about a month ago. Last week, we had a violent thunderstorm with high winds. This is in Kansas so that's to be expected.
I wasn't here during the storm, but the GM sent me a video showing massive amounts of rain pouring into the room. I was pretty surprised given the 4' overhang. We do get 50mph straight line winds sometimes so it must have been one of those storms. I climbed up and took a look and saw that there is a 4" box beam where the roofing terminates. I assume a lip was welded to the beam for the panels to sit on. I can't get back in there to get a closer look, but it appears that there is tight fit between the end of the panels and the beam. But I can't imagine the wind could have blown the rain into the overhang with enough force to lift it over the top of the beam, so the first thing I'm going to do is to try and reach back under there and caulk where the panels abut the beam.
HOWEVER, the upper roof pitches down so that it is only 3 or 4" above the lower roof on the west side. There's no way I can reach a caulk gun that far back. Is there some way I can fill the depressions in the roofing so the rain can't travel up the valleys?
