removing ceiling fan
3.5K views 14 replies 9 participants last post by  MechanicalDVR
I am removing ceiling fan and need to patch the hole. What is the best thing to use? Is there any patch kits out there?
Thanks,
#2 ·
http://www.thatdrywallguy.com/ This guy has some great classes on patching. I think that the depot sells his book, you might be able to read the parts that would help you while waiting in line. I am not sure if his web-site goes into much detail, check it out.
Check out www.jlclive.com he has a few free classes that fill up and are worth the trip. I went to one a couple of years ago and he had people come up and kick holes in drywall and repaired them during the 1 hour class.
#3 ·
Are you removing the electrical box? if not get a round blank deco cover to fit the screw width (3" or 4") Not the ones for a round junction box, they are nicer looking and made for just that purpose. Home Despot and bLowes sells them.
If the box is coming out, I generally take a piece of 1/2" or 3/4" plywood about twice as long as the hole and not quite as wide, put a drywall screw in the middle of the face of the board leaving 3/4" or so sticking out. Manuver the board up into the hole with the screw sticking down, center the board over the hole, and drive a couple screws through the ceiling into each end of the plywood, pulling down on the screw you centered in the board to keep it from moving.
Then, cut a piece of scrap drywall the same thickness as the existing ceiling to fill the hole and screw it to the plywood. (take the 'hold-down' screw out first ;) ) If you have some adhesive like liquid nail you can use that on the plywood if you want in addition to the screws, but since it is a floating patch it is really not necessary.
Two or three coats of EZ-20 feathered out and sanded, and once you paint it you will never know it was there.
#4 ·
Excellent point, you CANNOT permanently cover(like with plaster) or hide the box, there has to be access.
#7 ·
Sounds like a great idea, I'm not sure if there woud be a code issue or not in regards to access with a battery operated smoke detector covering the box, and I'm not sure about the regulations for the electric ones, I'll await a ruling from MD.
#9 · (Edited)
Seems like an okay idea to me. I'd worry about the AFCI protection requirement if this is in a bedroom. Seems like the battery type detector probably isn't listed as a blank canopy for a box, but a hardwired/battery detector is certainly intended to be used on a box.
Isn't there an interconnection issue in most locations with installing an additional hardwired smoke detector Added: Provided the house already had interconnected detectors? I also agree with your point about using a S/D as a blank cover.
#10 ·
Isn't there an interconnection issue in most locations with installing an additional hardwired smoke detector? I also agree with your point about using a S/D as a blank cover.
That's kind of what I was wondering about and also the possibility of the power being switched.
