Railing Post Too Short
26K views 20 replies 11 participants last post by  killerdecks
Replacing the deck joist, decking and railing for a customer. The existing railings didn't meet code. I need to bring them up to 36". The (8) 6x6 treated posts are currently only 32 1/2" high from the decking. The top rail cap will be a 2x6. My only idea is rip some treated 1/2" shims, put them on the post top, them a slab of 2x6 treated, then my rail cap 2x6. That will give me the 36". My concerns are...I don't think the 1/2" shim and 2x6 slab will hold up very well. Much less the problem with them splitting when I screw them rail cap down. It's right on the beach in NC. Very harsh sun, salt environment. Any better ideas out there?? Building the railing tomorrow. Thanks.
Joel
#3 ·
That looks great and is a very good idea. However, customer is on the cheap. It would be awesome if even half the folks I'm replacing decks for would go with sleeves and composite.
I guess if they don't want to pay for it, then they get what they pay for and the pieces start falling out in a year or two.
#6 ·
MJ, The 6x6's are extension of the deck support posts. I thought about cutting them off and just adding new railing posts. They didn't want to spring for the added labor/material. I already blamed the government...it's the building inspectors fault!
Griz, Good idea but they said it blocks the beach view too much. They said that's why the built them only 32" high before. I just said...gotta go 36" to meet code.
#9 ·
Rip a 2x8 down to 6" wide, problem solved. I pay about $20 each for Fiberon sleeves at Lowe's. Not sure how many posts you have but your clients have to understand they're limited in their options and you're giving them a couple good ones...Just tell them you ran it past the top deck guys in the country haha
#15 ·
What is the height for that deck? If you under 30" maybe you can get away with that height...
Tell the Homeowner to go down to the township and get a Code Modification Request form. Have him fill that out and there is a good chance this could fly having the deck height under 30".
Done that quite a few times with great success.
What you basically want to show that the modification you asking for is reasonable and it will still provide equivalent safety
Show that your requests is based on practical difficulty in achieving code conformance on the existing railing and in your case the deck is under 30" and that the existing rail being 1 1/2" short of 36" it will still provide equivalent level of safety and protection.
Explain as clearly and completely as possible the nature of the code violation and the proposed change to the following code and use these codes as reference:
R312.1 Where required. Guards shall be located along
open-sided walking surfaces, including stairs, ramps and landings,
that are located more than 30" measured
vertically to the floor or grade below at any point within 36
inches horizontally to the edge of the open side.
Add R312.2 Height. Required guards at open-sided walking surfaces,
including stairs, porches, balconies or landings, shall be
not less than 36" high measured vertically above the adjacent walking surface.
Include with that a drawing and a few pictures of existing condition and you shouldn't have any issues.
Good luck.
#18 ·
Thanks Greg, Never tried that. I'll ask my inspector about code modification request. I suspect he'll say no way. One job I have is a boardwalk from the house to the beach, over sand dunes. Railing is 28" high with 6" spaced pickets. The inspector told me and the owner, bring it up to code or tear it down and people can walk across the ground to the beach.
#16 · (Edited)
Cut 8 2" blocks from a 6X6 and epoxy them to the tops of the posts. Pre wet the end grains a few times of both pieces and use plenty epoxy so the joints are not starved. If you're worried about splitting use 2" longer fasteners and after drilling pilot holes, drill oversize holes in the 2" blocks. West Systems makes great epoxy for all sorts of applications. If you need to relevel posts cut longer blocks then trim posts level. Use any leftover epoxy to coat the end grain of the post.
