Status
Not open for further replies.
3,041 - 3,060 of 4,260 Posts
Brilliant work Jason. I take it that Azek must be PVC? You milled all of the moldings from Azek? How did you get the surface so smooth. My experience with doing things with PVC is that under the factory surface it is rather porous?
Steve
Nearly completed with this 1.3 million exterior restoration.
The entire exterior was removed down to the framing. New spray foam insulation was put in, new sheathing (zipwall), and all the siding and trim was made from new materials at our shop in Manchester, VT.
The siding is 5/4 x 6" Heart grade Redwood and the trim was made from Western Red Ceder. Some other elements like railings, balustrades, and pedestals where made from Spanish ceder.
There is a bluestone patio all around the house and the old Mahogany base and cap rotted away after only 20 years. For this reason we decided to make the new base out of azek. We took advantage of the pilaster locations and hid the expansion joints behind them and didn't make a permanent attachment from the cope joint returns of the pilaster to the base so it could move freely in different weather conditions.
(Many pics to follow)
Steve
Thanks Steve,
We use XLM primer on the milled parts of the PVC. That really helps the paint stick. After it was installed we use 2 coats of SW Duration. That fills in the pours very well.
I'm about to do some heating and bending of some milled PVC for some curved balustrades next. The porous condition you mentioned is turning out to have a set of it's own problems to deal with...
April Aerial photo
Here is the latest aerial photo from my school project. Biggest difference this month is that instead of mud up to our a**holes we are now sucking dust.
Great info. I didn't know that Sherwin Williams made exterior SW Duration. That's good to know. Keep us abreast on the bending project.
Steve
Thanks Steve,
MAGNETTICA:
As usual, Very thorough and Very neat! Where is your usual backboard and the stapling/tying of the exited wires?
Gettin' lazy in your Private Venture??? Huh? Huh? Explanation!!
http://i271.photobucket.com/albums/jj138/electricianron/IMG_0238.jpg
Jeees! Give a Man a Job and he will Excel! Give him the opportunity to build a Business and He gets all Soft!!
(I Laughed!!!)
One has a 7' ceiling the other has a 9' ceiling.
Generally, they're not too concerned with stapling the wires above the panel on an upgrade as long as the cables supported within reason.
I was just busting yer hump. All the way!!
One Day Shower Remodel
Job started with a call at 6:30 am with homeower calling saying the power was out due to a rare snowstorm. She said stay home, no power, no heat & she was going to work for heat. We showed up with a good generator, heater & pop-up tent and went to work.
Old tile was moldy, dirty 4" white missing a row due to a leak. Left Tub , Demo old 4" Tile , Installed new 1/2 hardie, Installed & Grouted in one day. House has built in 1940 , tub was short , used small rips at edges with bullnose. We installed two inset shelves for soap/etc.
We also did a backspash at the same time.
Raine, shine or blizzard the machine keeps going.
Before & After Shower Remodel
Total bathroom remodel. Removed old fiberglass shower & add 6 inches to length. Used corner seat kit & poured new shower pan. 3 days with 2 guys doing tile & 1 guy 2 days Removal of large soffit/firdown ,wallpaper removal , smooth finish text & paint, Installed new lights. Total 5 days
Status
You have insufficient privileges to reply here.
