The cold steel rod reinforcing the underside of this sink cutout should have been stainless steel, fiberglass, or composite, should have been bedded in epoxy instead of polyester, and the sink should have been properly installed. Note the crack just above the far left faucet hole. As long as the rod oxidizes and expands, it will continue to destroy the top.
The front edge, cut in front of the front rod, will become the rear; the beveled edge will slip under the backsplash while the newly cut edge will be profiled and polished.
The blown rod shows itself. The cut exposed ends are ground back and filled with stone and color match methacrylate front and rear although the rear repairs are covered by the new rear rail.
You won't find this sink online or at your plumbing supply house. It's my design, custom made for this job, and I have it fabricated in the states. 14 gauge stainless steel; over 70 lbs. shipping weight.
The bottom of the apron aligns with the bottom of the adjacent drawer perfectly, the sides of the apron align with the lower doors perfectly, the rear edge of the apron kisses the cabinet on each end equally, and the slight positive reveal on each side of the sink is perfectly consistent. If you're evaluating a similar job, those are the things you're looking for.
