Making some big azz doors. a pair of 48" x 84 5/8" doors. So the opening is 8' wide.
The original door profile is different. It's a Classical Pattern edge profile. I told them I could get the cutter set if they wanted to shell out the $900 for it. They didn't, imagine that :laughing:
So I have a large thumbnail cutter that I use for wainscoting. The profile is designed for 7/8-1 3/8" thick wood. So for 1 3/4" thick material I have to play some games.
I setup the cope with just the thumbnail and one of the flat cutters that determines the depth of the tongue. The stick cutter is the thumbnail the the slot cutter. The setup is very thickness dependent. Small variations make the joint tight because of a slight misalignment.
I ran some test pcs and had chipout with the Vertical Grain Douglas Fir. I thought this might be big trouble for me. But then I tried running my profiles with climb cutting and it worked great.
Here's the cope and stick setup in my test pc. The center slot on the cope is cut on the tablesaw.
Here's real life parts
Did a test setup of the bottom of the door which will contain 4 tall panels
And this is my test setup for the 8 lite window at the top of the door, it's held together with a 3/8" dowel
That's as far as I got today with the door.
