799K views 12K replies 233 participants last post by  tjbnwi
Previous Threads.
Part I
Part II
#7,109 ·
#7,102 ·
That looks better
#7,114 ·
I can’t make sense of the two rows I marked. The only difference I see is one mentions having OSB and the spacing goes from 24 to 8.
8” OC studs when you have OSB sheathing added to the assembly? What am I missing?
That almost sounds like they want you to nail in between the studs into the osb.
Sent from my SM-A115A using Tapatalk
#7,116 ·
I think Randy's right because in the upper red line you marked it says the same nail at 24" o.c. max so there's no need structurally for an 8" o.c. stud spacing not to mention how extreme that would be, good luck getting any holes drilled with 8" o.c. spacing.
I'd definitely check with Allura tech department to verify but yeah, it looks like it's saying to nail through the sheathing in the bays.
#7,117 ·
The nailing schedule also says that it needs to go into the framing a minimum of 1-1/4".
There is something wrong with that particular row of information.
Maybe it was supposed to be metal studs or a different fastener size or something because it is not making sense.
Andy.
#7,128 ·
That doesn't look like the picture.... 😆
#7,127 ·
I had to figure out how to hang an attic ladder by myself.
Lo and behold, I had some door hanging brackets in the truck.
They held just long enough for me to sink some screws in the attic.
I don’t hang them very often, so I haven’t refined it, but I have a better idea for the next one.
#7,129 ·
Which will happen just as soon as you forget what you did here. :D
#7,130 ·
I think I’ll just run a 2 x 4 across the top corners and across the bottom end of the ladder framing next time.
Leave about a half inch gap between the 2 x 4 and the attic ladder framing surround for adjustment.
That way, after dropping it down into the hole, I can adjust height and secure it without having to support it with one hand.
#7,138 ·
Been needing to replace two 6’ thresholds for my wife’s grandmother. It is a sunroom and as you can see the thresholds were totally ruined. Questionable construction methods (brick sitting on slab at same level as bottom plates.
Been so busy I’ve been putting it off for a month and so today I just put off everything else and got my carpenter buddy to come over and we made a day of it. Real pleased with how they turned out and everything went very smooth and sealed up tight. Replaced the bottom 6” of the jambs and replaced side casing on one door. Cleaned the concrete underneath very good with a masonry grinding disc and a damp towel. Good silicone bead underneath and along the front edge.
Best part was it is half a mile from my house 😎
