Jack stud question
34K views 45 replies 21 participants last post by  wallmaxx
Ive been framing since i was a kid like most you probably since we could carry a hammer.
Ive been framing new homes for this builder for about 5 years now. they are all custom williamsburg style homes 4000sq ft and up. we just finished framing an 8 unit townhouse project. he is a penny pincher and he approached me the other day about my window framing method.
I always us a full jack stud beside the king stud then my sill board with cripplers on the bottom.
He would like to see me use just the king along the window with a split jack setup. he claims this will save material. I have not really had time to think on it i just wanted to throw this out to you fellas.
Like any of us we tend to get this weird feeling at our ass when someone picks on our framing methods. any ideas would be welcome as i know you guys are framers as well. thanks
Also is this faster or slower. stronger or weaker?
#36 ·
you have to have cripples above the header? We do stuff like that quite a bit.
Sounds "old school" to me.
The very last time I put the headers down at the top of the door RO was on a multi-family job where the doors got changed to metal framed from standard doors. Had to change out all the first floor unit entry door headers.
What a PITA.
Since then I put ALL headers up tight under the top plate and furr down to the door RO top. All my sills (doors and windows) get double plates...stiffens things up and provides a bit more wood for the trim man. Its a much easier way to change out openings...IF EVER REQUIRED.
#46 ·
Those are very cool for openings that are tight in between exposed columns like in the two Lindal's I have and am doing. They send out windows that fill the space between the posts, which leaves you very few header support options. Their primary method in the plans is to run MST 48 straps horizontally across the top and bottom edge of the header. I did the first one like that...what a pain for nailing / screwing the trim. You end up having to pre-drill through the trim and strap just to attach the trim to the house.
Look above the ocean side openings
I am doing another (when the snow lets up) and I am going to suggest the header saddle type. HUC I think.
