21 - 34 of 34 Posts
wonder if you upgrade the chain and lock so much that the thief will cut the two hinges for an easier entry?
having a ring camera and motion sensing light at the entrance may be a greater deterrent than the upgraded chain and lock combo.
Every day I pass a car wash under construction near a major highway, that place is lit up day and night inside and out. Has huge windows along 1 wall and the entire lot has a 6ft chain link fence and numerous cameras.
Directly across the street is a motorcycle dealer set up the same way, this summer they caught 6 guys inside the fenced in area. They were picked up on the cameras.
A heavy duty wire rope might be a possibility. It’d tend to bind a grinder more than chain, and since I doubt thieves tend to maintain their bolt cutters, they’d struggle to cut it without having to cut each strand. Might not work, but it’s an idea. You could also weave some cable through the chain links to try and get the best of both worlds. Do your best and keep a property insurance or inland marine policy for the rest.
As an additional idea for either the chain or wire rope, maybe wrap some old chainsaw chaps around it and rivet them or something. It seems like maybe they’d bind a cutting wheel, but I’ve never tried it. It’d be nice to immobilize the grinder before it even hits the chain or rope.
To be a bit more detailed, ol Don was another iron worker turned carpenter. 1 of my mentors as a young gun. He spent some time, & I’m not talking 6 months or a year in 1 of those less desirable dwellings. However, the smartest man & best carpenter turned GC I ever knew or will know.He once told me he spent all of his time on vacation studying & reading. He also wanted to see us young guns advance. Sorry for the derail Reg but you got me to thinking
Mike
Discussion starter · #30 ·
Mike
I like this derailment. He sounds like somebody I would get along with.
Doberman or two would probably do the trick
I have two at my feet as we speak. Must be defective. I'd be on the roof doing stuff and look over and Boss, Neighbors, crew... they would all be hanging out by my truck at some point because the bigger one, Morgan, was there and he'll climb up in your lap if you let him. He's (mostly) all snuggles.
Wolf hounds could snuggle people to death....
I ran into similar questions a while back and ended up talking to someone from locksmithforlondon.co.uk—they gave me solid advice on chain and padlock combos that actually hold up in rough environments. They're used to dealing with setups where brute force attacks are common, so they had some good pointers on chain thickness and shackle clearance I hadn’t considered at first. Worth checking them out if you're stuck.
21 - 34 of 34 Posts
