21 - 40 of 62 Posts
Pics viewed over a computer screen are useless when it comes to color selection. I really have no idea what that tile looks like in person. Also, what the customer's expectations are is not something I'm aware of.
With the literally thousands of feet of urethane I've installed, color has not been an issues. I'm trying to see if I can find pics of any cream 210 I've installed.
Discussion starter · #22 ·
Yes I understand computer makes it look different but I compared the color to the sticks and it looks nothing like it.
Have you done any beige/white floor in high white? Any pics by chance of whit and cream colors you've done? I can go and bring it back and get another color but what if it looks worse than this one?
Part of doing a tile job right is using the right grout. A professional tile man who has been specializing at it for a few years will have a much better chance of getting it right than someone trying to do so by asking questions on the internet.
Not sure that this is a valid statement. Your ability to install a quality tile job has little to do with how well you coordinate colors. Some of the worst color recommendations I have ever seen came from great installers.
Of course it's valid. Put yourself in the place of Helen and Harry Homeowner, the people we all want to please.
Two installers with equal mechanical ability, but one has a great style and color sense as well. Which one are they more likely to favor? Quality is not mechanical ability alone; robots can do that.
But my point was that even someone with little style sense will, with enough experience, know how a sample compares with what the product looks like after installation. That kind of knowledge is extremely difficult if not impossible to convey over the internet.
Discussion starter · #33 ·
Angus, quick question for you. I just did an install of 1500 ft of unglazed porcelain that states should be sealed on the box. The tile recommends cleaning it with an acid then sealing after grout. I did a small test on a 24 hour quartz lock and the acid did not seem to moisten it or change color.
Would you do this prior to quartz lock to help remove the haze better or after the grout is done? I am just wondering if the sand in the grout will remove parts of the sealer and need reselling again after.
I am using DuPont stone tech bulletproof sealer.
Laticrete SpectraLOCK color Change due to long term exposure to UV?
Yes, our literature states:
"Light colors may darken and dark colors may fade slightly
from direct UV exposure in exterior applications. Consult
with LATICRETE Technical Services for specific exterior
recommendations."
This would be based on LONG TERM direct sun exposure. Particularly in "sun intense" areas such as FL, AZ, Queensland, the UAE etc.
SpectraLOCK is rather well proven for exterior installations and does NOT exhibit extreme darkening or fading !
Henry
21 - 40 of 62 Posts
