I just drove by a fence job (privacy style - treated pine) I did last summer to see how things were holding up. All was well except the gate. The bottom part on the latch side of the gate was bowed out of line with the post to which it is latched. I have seen this happen in at least one other gate I have built.
I am pretty sure that the cause is the fact that they were built in extreme heat with treated wood. And the quick drying of my gate framing is causing it to twist and pull more than it would in cooler weather.
I am sure that I will build more gates this summer with treated pine in extreme heat, however, I want to prevent the bowing. The two solutions that come to my mind are to either keep a stock pile of treated lumber on hand that will be good and dry before use. Or, I thought of using cedar 2x4's for the gate framing only.
Does the cedar option make sense, or will it also be prone to twisting in extreme heat? I realize that the color of fresh cedar would at first contrast against the color of fresh treated pine, but I am thinking that after they both faded a little, the contrast would be minimal. It this correct thinking or am I way off track?
You input is greatly appreciated.
