Framing arches
16K views 49 replies 22 participants last post by  Calidecks
I'm working on a job that has a ton of arches in the walls. A soffit along metal beams with 5 sections between the steel posts that are all arches. Doorways with arched tops. Arches in walls for displays. Arches everywhere. I've done arches in the past and most of them at this job are done. I made them out of plywood and to lay them out I used a piece of FRP paneling J trim that is flexible to get the shape of the arch and traced it. But after doing a dozen arches today there has to be a better way to lay these out. What are your tips or tricks for doing arched doorways, arches in the walls or soffits where the bottom is arched? Especially how you get the arched shape laid out? I was working by myself most of the day and some of the longer arches were a little difficult to get the shape laid out by myself. Are there any special tools to get the arch shape laid out on a sheet of plywood?
#41 ·
Some places just shouldn't have ab arch for aesthetic reasons. Even if an arch could be good, not every arch is going to look good in that location. I've seen some that I think the remodeler threw in for the extra $$$.
Any good drywall guy should be able to finish arches of any radius, it isn't that hard.
#43 ·
I have to agree with above. It all starts with the quality of framing, but the drywall finisher has the last say.
#44 ·
Lone....you da man.
That last picture...the free standing spiral staircase. I've only done one (as a helper) back in 1990 in Houston. Looks like an amazing job as usual! We used 5 layers of "Chinese" plywood, to make each curved stringer (ÂĽ" thick stuff).
I'd give you 2 thumbs up but the emoticons aren't on the iPad so far as I can tell.
I love your pics......your framing of complexities is masterful. Thanks for sharing.
#50 ·
I used to do grocery store, store fronts. When we did all the conversions from Lucky stores to Albertsons, the arches were so so big they took up several sheets of plywood. We used tie wire and the parking lot.
_________________
[emoji631][emoji631]
