Framing arches
16K views 49 replies 22 participants last post by  Calidecks
I'm working on a job that has a ton of arches in the walls. A soffit along metal beams with 5 sections between the steel posts that are all arches. Doorways with arched tops. Arches in walls for displays. Arches everywhere. I've done arches in the past and most of them at this job are done. I made them out of plywood and to lay them out I used a piece of FRP paneling J trim that is flexible to get the shape of the arch and traced it. But after doing a dozen arches today there has to be a better way to lay these out. What are your tips or tricks for doing arched doorways, arches in the walls or soffits where the bottom is arched? Especially how you get the arched shape laid out? I was working by myself most of the day and some of the longer arches were a little difficult to get the shape laid out by myself. Are there any special tools to get the arch shape laid out on a sheet of plywood?
#4 ·
They were mostly radius arches. The way I did it was with a piece of flexible trim. I screwed a few temporary screws in at the ends and the center point and used the flexible trim to get an arch. So I'm sure they weren't perfect "circle" arches but closer to radius then elliptical. I will try to get some pictures tomorrow.
#8 ·
Strings will stretch. If you want an accurate circle or ellipse, use the trammel method Bob posted or a single stick for laying out a circle.
In remodeling, you may have to enlarge an existing rectangular opening to put an arch on top. You either have to put some structure in the opening to be able to use a trammel or stick, or you can take 2 straight boards, put one nail through at the ends and clinch it over so they act like a big bevel, put nails in the wall at the locations you want the ends of the arch, then move the hinged part up the center line of the opening until it's at the height of the arch you need. Put some screws in it so the angle is now fixed. Draw the arch by letting the legs slide on the 2 nails while holding a pencil at the point of the angle between the legs.
For smallish circles, you can do that with your framing square.
#9 ·
We cut arches ahead of time on the CNC and deliver them with the framing package.
Depending on the situation it's often less expensive than laying them out on site, and more accurate.
We also cut TDC and level chord indicator marks in for easy alignment.
#12 ·
I use the basic calculator at handymath.com. You can also lay them out on the ground by selecting a starting point (shoulder) and a finish point at the top center. On a remodel, sometimes with a big radius it can be difficult to find the room to swing the radius. I have done a few at home on the concrete, and then taken them to work.
#20 ·
RPN for HP 50G Calculator
Find Radius for Arch
"SPAN INCH" "" INPUT OBJ-> 'S' STO
"RISE INCH" "" INPUT OBJ-> 'R' STO
S SQ R SQ 4 * + 8 R * / 'RADIUS' ->TAG
{ S R } PURGE
So a 72" wide opening with a 16 inch rise from where the arch starts at the edge, up to the peak, would be a radius of 4'-0 ½".
I can't remember the CM way to do it, but I will check my old note books when I get a chance.
#23 · (Edited)
So:
where S= the Span of the opening
where R= the Rise from the chord span to the top of the arch
Radius = (S^2 + 4R^2) Ă· (8R)
But that just makes it part of a circle. An ellipse/parabola is different entirely....unless you're framing for a math professor (like I did for a Rice U math prof once) you can eyeball half of it and flip it over to keep it symmetrical.
The RPN way is way more fun.
