This job is about 1000 sq/ft of deck with skirting not including railing and balusters.
2 decks total - one small one and one large.
It's about 12 years old.....maybe 10...who knows....
All pt lumber, well built, decent condition, most of the original stain has already gone to stain heaven.
Plans are to mask everything is danger's way, pressure wash, use a wood/stain stripper, then a 'brightener' (oxalic acid), and let it dry out for a couple of days.
Questions:
What strippers have you had good experience with?
When staining, would you mask the top boards and do the railings first or go after the top boards first?
I plan to spray as much as possible, along with touch up brush and rollers.
I've redone smaller decks before. This is a larger 'redo' job than I've done previously, and I'm trying to plan it for best efficiency.
The new stain will be either a semi or solid...undecided at this time, 2 coats.
There are no fragile parts to the decks, skirting (5/4), etc.
Questions:
