I have a project starting that the architect wants the electrical boxes to be in the center of the block rather than at bottom. Has anyone else seen this before? If so, what type of router tool works best?
I do stuff like this all the time. Finish block, finish bluestone. Need to have skilled craftspeople doing it. 4" grinder cut as deep as you can, score, cut diagonal. Tap out with a small sharp chisel.Well I hope that was in the specs then and you caught that before your bid. Score them with a grinder, drill holes and knock them out with a chisel.
That's the whole point. "Pay me". What the architect is asking for is not considered normal means or methods. Soooo like I said, sure it can be done. But it had better been called out in the specs. It hardly takes "skilled craftspeople" to cut boxes in CMU. But it takes a lot of extra time (money) to cut it the way the architect is asking for.I do stuff like this all the time. Finish block, finish bluestone. Need to have skilled craftspeople doing it. 4" grinder cut as deep as you can, score, cut diagonal. Tap out with a small sharp chisel.
Pay me and I'll come out and do it for you. :clap:
Brick -
Apparently you are a small customer for the limited block producers in your area. The Ivany is an old, archaic (40 years old) they was made for a different purposes.
Few contractors buy enough block to be able to get specials made and will not pay the price. The good supplier of architectural block spuuplier (especially burnished and colored) can get the block from a supplier or make them and finish them with cut-outs to mason contractor.
I have seen colored 8" burnish/ground block made with one flush en and one with "ears", 2 cores that were different sixes and one had a solid bottom. - It was worth it for the project and fortunately, the architect had it on the architectural and acoustic drawings for a concert hall.
If it is not called out in the spec or a detail in the drawing it has change order written all over it. I agree it can be done but at an extra cost. Never mind all the bends you have to put in the conduit above the box to miss all the webs or you are going to have to cut the center web and close pin all the other cmu above.That's the whole point. "Pay me". What the architect is asking for is not considered normal means or methods. Soooo like I said, sure it can be done. But it had better been called out in the specs. It hardly takes "skilled craftspeople" to cut boxes in CMU. But it takes a lot of extra time (money) to cut it the way the architect is asking for.
Not that I want to get evolved but I am from the area and we have quite a few large cmu suppliers manufactures in the area. Clayton Anchor Block (Old Castle) and they will make anything you want if your order in advance and want to pay to tool up. And Ivony block are a usually a stock item around here but it is for a retaining wall. In our area two hole block is standard cmu.Brick -
