best way to attach chair rail to plaster wall
15K views 16 replies 12 participants last post by  detroit687
#1 · (Edited)
Message deleted
#12 ·
I'm curious as to how you guys deal with this too, I'll reveal my method later.
The house was built from the 1900's to the 40's, plaster over wood lath. Here the base plaster material (local) is sand and shell. 16 ga. nails wad up in the gun and larger ones just explode the wall.
#13 ·
I have never ran into anythign around here that a 16ga wouldn't handle. But if I had what you have teetor, I would probly use liquid nail on the back of the chair and predrill through the chair rail and the plaster and drive hand finish nails into the studs.
Unless the hammering would crack the hard brittle plaster?
In that case I don't know what the heck I would do:laughing:
If its painted, maybe trim screws or something like that.
#15 ·
Sorry, forgot to mention that most of the wood back then was Dade County, also called lighter pine. Harder than a whore's heart. Hitting studs also gets you nowhere IF you could get to the studs.
