We have a Allied 8700C for our JD 310D.
Allied has updated their models in the last year, and the 8700 has been replaced by the 1000 model. All their new models have more impulse force, and by the specs it looks like it. Our 8700 is rated at 6,400 lbs of force and the 1000 is rated at 8,000 lbs, both at 2,000 cycles per minute.
The newer compactors have a choice of GPM for the hydraulic motors, so make sure your machines flow matches the motor.
Also don't forget the hydraulic kit for your machine. We got our kit from Allied and it was perfect, steel lines running up the boom, all hoses, switches, mounts, etc. The kit installed and painted ran us about $2,200, and also included a valve to vary the flow with 3 positions. We needed the valve so we could run the compactor or our breaker as each has a different flow requirement.
As for problems we have only had a couple. We bought this compactor used at a RB auction. After about a year we had a bearing go bad. It was a easy fix but I somehow missed a roller that was stuck in the grease where to weight rotates. Put the thing back together and fired it up and it promptly got stuck. Tore it apart and found a mark on the weight so knew something was in there and found a roller that fell out of the old bearing. there is a lot of grease in the housing where the weight rotates since that compartment is just a place for the old grease to go when you grease the bearings. The only other problem is with the hose fittings on the hydraulic motor coming loose every once in awhile from the vibration. And again not a big deal just keep a eye on them and tighten when needed.
But once you have a compactor you wonder how you lived without it. Before we bought one we used to rent another backhoe with a compactor when we needed one on a job, this was also before we bought our 928G loader. So now the 928 brings the gravel to bed the pipe and the 310 follows and fills and compacts.
