I am wondering could you use a 4x4 as header for a window or door for 2x4 outside garage wall?
Andy.... why'd you say "no glue".... no advantage/unecessary????Absolutely you can use a 4x4 or 2-2x4s for headers.
depends on the span of course and the width of the house and what it is carrying.
You are in Alabama, so no snow load of course, and house is about 28 feet in width. You are allowed to go about 42" for a man door let's say. Or if the house is wider, then about 35" for a door.
Personally I like the 4x4 because of the ease of install but I actually preferred to make the header out of 2x4 with Ply. no glue, 16d sinkers top & bottom oh, 6" o.c.
Andy.
That's more work and more lumber I got to buy.
Statewide you have to meet 2009 codes (at minimum) & you are in a wind zone - so you should be using insulated headers - 1/2" thick foam & 2 2x'sYes we use 2x4 headers all the time in trade school. We only have to do go down 12'' for slab footings. I think our codes are a little lose.
It will not hurt anything at all to glue them if you want.Andy.... why'd you say "no glue".... no advantage/unecessary????
Just old custom, I've always thrown some LN or PL in the ply???
I'll bet you are dead right/correct.... many years ago I had a (AH) BI inspector that liked it (never called him on it)..... ever since then I got used to even making sure I had some squeze out so BI's could see it...It will not hurt anything at all to glue them if you want.
I am just not convinced that glue does any good as the nails take all the shear forces between plys.
I just think it adds a bit of messy complication.
Andy.
Do you have to use glue?Statewide you have to meet 2009 codes (at minimum) & you are in a wind zone - so you should be using insulated headers - 1/2" thick foam & 2 2x's
You have worked hard trying to develop & establish your name, do it right & don't cheap out
There are better ways to save money on materials & still end up with a quality product, here are a few: http://blog.sls-construction.com/2012/common-sense-ove-framing
Why bother with the 8d's? Especially since they'll shine through.CJ21 said:We just nailed the 1/2'' OSB with 8 penny nails and the header with 16 penny nails.
:thumbsup:Seriously though, if code allows it, I don't see anything wrong with a properly sized solid header. IMO it is stronger than 2 boards nailed together.
Come on, Hoss.That's more work and more lumber I got to buy.
The stick framing we have today is a direct result of needing something faster and easier than timberframing. At some point in time, somebody didn't love the work of traditional framing so they came up with stick framing. Just saying I think coming up with different ideas is not always bad.Come on, Hoss.
You spent more time starting this thread than you would have just building a damn header. :blink:
If you don't like and love the work, you should get the hell out of the trade. Not being mean, I just think you'll make yourself alot happier.
I have just as much trouble with twisted 2x12's. I've also ran into a lot of "fake" 4x12's where they just used a 2x4 on the bottom of the outside.Texas Wax said:Biggest problem with 4x4's (properly sized of course) is they twist.)
That's what I was thinking, we usually fill the back side with epsScipioAfricanus said:Could that have been a box beam header? Those are quite handy and are code compliant. I think R602.2 ( if I remember right). Andy.
