22 year old need tips (welder rig)
4.4K views 9 replies 8 participants last post by  Thom Paine
hello, I'm trying to start a small repair & small fabrication setup, I just got my self a old ford 1 tone truck that needs a bit of work 1st but once that is done id like to uses it for a welder rig, I'm autistic but love to weld, I'm thinking getting a small engine driven welder (stick/tig) and do small repairs (fencing & bucket), be a small contractor type thing, I'm in Montreal, Quebec. so il go challenge the stick/tig tickets and get my stupid RBQ certification, but what tools and things be nice to have for a small welder rig? should I go with torch or plasma cuter ? how to start getting contracts ete. I'm looking for advice and how to be as professional as possible and be properly equip for the job!, I don't have much founds but in a year I want to get started ! so trying to do all my homework and slowly get it done!
#2 ·
Don't know about Canada but I have family that are rig welders. Never saw any of them with a plasma on the truck but they do have oxy/acct rigs on the truck.
No TIG torches just stick welders.
You will need squares, tape measures, some hand tools
As far as getting clients it will take some leg work and dropping off a lot of business cards
Might try to get a job as a welders helper to get experience and then start to make contacts so when you break out you will have the necessary contacts to get work
#4 ·
thanks, for the information, I tried applying for welder helper or apprentices but due to the fact I'm autistic I get turn around, I'm very good welding and fixing things, but unfortunately not many understand what is autism!. il look into oxy/acct and the small tools, I have 2 years of experience with my high school and hobby. I know small repair and fabrication for the most part but still have lots to learn that's why i'd like to start small jobs. and ark it is =P
#6 ·
Keep knocking on doors sooner or later some one will gice you a chance :thumbsup:
Arc, oxy/acc rigs and tips cutting, rose bud, then work off the list from Griz.
Keep us up to date on how things work out for you ;).
#5 ·
Size of welder will depend on how thick of steel you can and are qualified to weld.
Definitely need a gas set up for cutting a d tips for heating.
Also a generator, maybe part of the welder, good size drill motor, industrial bits, grinder or two, air compressor, industrial impact wrench, assorted hand tools, lighting, come along or two, big pry bars, jacks, jack stands, big blocks of wood, couple of fire extinguishers, couple of chains, throw down mat to work on the ground,full water jug etc etc etc.....
#7 ·
Plasma cutters are great for cutting thinner metal. You can scroll through sheet metal like a jig saw.
I've used my plasma cutter on thinner metals and no grinding or demurring was necessary...very clean cut.
It will cut heavier metal but it will make some rough cuts.
A torch is much more versatile....especially if you have to bend metal.
Whichever you choose you will have many times when you will have to grind the cuts to smooth them out.
