Wrapping brick moulding/jamb in one piece
27K views 42 replies 18 participants last post by  EricBrancard
I'm sure it's possible. I'm doing it. I just can't do it without a little bit of tweaking by hand. The problem is the 1/2" bend where the brick meets the jamb and 1/2" of the jamb is visible.
I start on the outside edge at 1", then use a roller for the profile, and so on till I get to the 1/2" bend. But the piece stops at 3/4" in and can't go to 1/2".
My method is to leave the last bend angled a bit which lets me slide the piece in farther but then the only way to finish the angled bend is by hand.
Any help would be greatly appreciated.
#4 ·
Trick for bending 1/2" or even a 1/4" bend is pretty simple.
Just make the first bend at a 45*,flip stock,and metal will
slide in close enough to get it to the 1/2" width.Bend this
at a 45* also then flip again,get first 45*to a 90*,flip and
finish.
By not setting the first bend at 90*,you'll be able to get past
the edge of the hinged section of the brake.
If you have to make a 1/2" J section you can put metal scraps,
extending past the lip of your first 90* bend,set your stock at 1/2",
and the scraps will hold your stock in place.
Hard to explain,but it works good once you've done it a couple times.
#6 ·
Thanks John for the description and Tom for the pictures. I tried a little free hand bending today and that worked better than using the roller for the profile part.
The roller works well if you're ok with two pieces but it doesn't look like I can do it with one piece. I'll use some of these techniques and try again tomorrow.
#7 ·
Those 1/2" bends are tricky for that and it reminds me of wrapping around exterior wood stops left in place on one piece brick mold window casing wraps. The Pro's nailed with their description and pictures. I wish that I would have had seasoned guys like that to learn from in my early days. Having to figure the brake bends out by trail and error sure burnt some of brain cells over the years.
Going partial bends with just 45 and flipping is how I do it.
#11 ·
But then you get into the issue of nailing it. I hate nailing aluminum. Maybe I don't know what I'm doing but I get pieces that look nice and then take a nail to them and they look awful.
I'll take a picture tomorrow of a piece I made that looks terrible now. I have a way I'm going to try and fix it, but anyway...
Doing the one piece it just about doesn't need nails by the time you get it on. I really don't like the nails on the jamb face as it tends to make the piece not look as good.
All that said, I respect your siding/aluminum advice a great deal and would love to hear more on your preference of 2 piece wraps and why they are easier.
#16 ·
experience is all it is and i have nothing figured out..:sad:every job is a little different with different problems,if i'm good at anything it's how to fix my own screwups
like i said the 2 pc gives a little more flexibility,remember no piece of wood trim is as straight as the brake,also .019 coil is pretty flimsy stuff,you may find even tho the edges are nailed the center may tend to ''puff''out
go to a siding supplier and pick up a trim nail punch..it's under 10 bucks and will become your best friend
#14 ·
Like Tom I do all of mine in two pieces. Alot of the doors jambs anymore seem to be less then 1/2 ". I have at times I have used silicone caulk to glue them to the jambs , which so far seems to have held up. One thing that seems to help , at lease for me, is to not set the nail with a hammer but rather use a nail set or such to do it, I use a old door hinge pin. also I don't use the painted trim nails with the waffle head, use a # 3 and will even clip the head some too and use touchup paint.
#23 ·
I've always cladded my jamb and brickmold wrapping on by back caulking the aluminum with Novaflex. No nails ever. I hem the inside return of the brick molding to help with rigidity. Having a modern well tuned brake is paramount. I also perform this in two separate pieces. I've found that 5/16" for the return to the inside by the weatherstripping kerf works for me without obscuring the kerf. Standard new construction jambs will have about a 2 7/16" jamb face give or take some frog hairs. I go about 1/2" to the face return unless I can go heavy and slide behind the brick molding.
The brick mold profile is done either free hand or with Van Mark's trim former that runs 2" heavy on the face to account for the hem thickness on the inside return which is typically 1" heavy. The outer return I try to get as deep as possible depending on the installation. Never seen any oil canning or problems with blind caulking or cladding the metal on.
#34 ·
It's also a stabila level with the flat part of a sharp carpenter pencil guided down the side. So I guess that's a stabila plus half the width of a carpenters pencil. The point is no measuring needed and it turns out perfect every time. Hopefully this makes since. If not I will try to get a few pictures.
#39 ·
I'll never use wood brickmold on the outside anymore...if the frame is getting capped I'll bury it behind PVC BM.
No need to get fancy with the brake especially around doors.
