Would you even bother with the curve?
11452 Views 63 Replies 28 Participants Last post by  Easy Gibson
Putting up crown in this plaster room and there's a slight curve in one of the corners.
It's so slight that I'm wondering if I should even bother "doing the do" or if I should just miter it and back cut it a bit to sit even on the wall.
Lousy picture, but you get the idea. What does the jury think?
1 - 20 of 64 Posts
Are you asking whether you should radius the crown? Miter it. I think a curve would look odd.
That's the answer I was hoping for. hah
I'm doing the paint too so I get to be responsible for the finished product which is nice.
This is Central Park East, a block from the Guggenheim. It's a condo on the most expensive residential block in NYC. The neighboring building is a 6 story single family. I didn't know that even happened.
Since you're painting- Can you take it a step further and float out one side of that so it meets in a defined corner?
Since you're painting- Can you take it a step further and float out one side of that so it meets in defined corner?
Will the customer pay for that?
With the wall access panels running to the ceiling, crown seems a little unusual. Small profile?
If they live on Central Park East, money isn't a concern.
You have to do it as a curve. :whistling
Reactions: 2
Heres a pic of almost the same thing. We did a mitre but Split the angle again to have a small pie piece so it wouldnt have a big bottom gap to caulk.
Reactions: 5
Thanks for the pic, Trim!
That's something I was considering. I've only done crown over plaster once and it actually was with a giant radius. Really annoying. Took all day. hah
If the client is what I suspect he/she to be based on the address I can't imagine doing what is shown in the pic and not having it come back to bite you.
It would be best to follow the curve in plaster. It only takes a few minutes to make a profile knife.
This is an outside corner, but it works the same.
Reactions: 5
Put your Nike’s on and Just Do It! Prolly not the answers you were hoping for :laughing:
Man, that's freaking AWESOME!
Reactions: 2
Bass rocks!
Wondered if someone would put that up. I remember when you first posted that. :thumbsup:
basswood said:
It would be best to follow the curve in plaster. It only takes a few minutes to make a profile knife. This is an outside corner, but it works the same.
That is what separates the men from the boys, and yes I'm still a boy :laughing:
No doubt. It probably only takes a few minutes to tune a Stock Car as well, but I'm not gonna try it. :no:
that's some sweet stuff Bass.:thumbsup:
Reactions: 2
Holy ****!
1 - 20 of 64 Posts
