1 - 11 of 11 Posts
A while back i was amazed to see how a wood chipper literally chewed logs into mulch in seconds, i never seen it before first hand.
But i have a question, if i were to feed old barn wood siding into it with nails, would that be a problem for the chipper?
Not that im going to attempt this, but im curious about the limitations of the machine.
Thanks
· Sean
First it depends on the machine - the larger commercial machines can easily handle it (even some resi models) but I can almost guarantee you that you would damage the blades thus shortening the life of the equipment and it would not be a real good idea.
I would recommend finding someone that buys reclaimed wood truthfully & make some money off of it
I tried... many many many interested people.... none came through.
Just don't put your ex-wife in a wood chipper, especially if you are in CT since they are wise to that tactic and got famous for the forensics a few years ago.
With a regular brush chipper nails would dull the blades kind of fast, they could take a few no problem but when they get dull they feed much slower and chip much worse.
A tub grinder has carbide tipped hammer type teeth that just pulverizes everything, no problem for them. Our county grinds pallets with one of their machines.
That's the kind I was thinking of, I've seen this type where it just eats
The cyclinders with teeth rotate and bang tight to each other and can open to about a foot
1 - 11 of 11 Posts
