Screen name "Angus 242" will undoubtedly chime in on this question. Listen to him-he's really knowlegeable about questions like this.:thumbsup:
Me is confused :blink:directly to 3/4 x 4" floorboards
16' span with 2x10 is pooh pooh. That needs to be addressed before any tiling happens. Can you sister on the outer sides of the bay with the mechanicals? Your deflection ratio is currently around L/270 :thumbdownangus, the subfloor is the 1 x 4 t & g. i guess it was confusing when i said 3/4 x 4. the underlayment is TBD, cbu, Ditra, only on subfloor or plywood first then cbu or ditra then tile ? thats what i'm trying to figure out. the tile, 20 x20 & 13 x13 cermic. i was just kidding about jumping on the floor. but the 2 x 10's are spaced 16 oc and the span detail is above. 6'+ tripled up for stair opening & 16' with bridging.the species? its not a stone so i have no idea, possibly hemfur ? house built in 1950's maybe yellow pine. hope that helps.... SO you LIKE the Ditra, A. thanks for your help. D.
angus, unfotunatly the vent prohibits me getting a sister in that bay and the next bay over contains the return, however that is under the hall wall if that makes a difference. the other bay is next to the steps ,that side is doubled for stairs then a third about3/4 "away from that, no blocking. the otherside i can remove bridging and probably sneak in a sister, however the joist on the other side of the beam is there leaving me no bearing . i could put a spacer, a 2 x4 top & bottom on that joist then add another 2 x 10 x 16' if that is copacetic. if not i suppose i can add a small beam & posts right on across the 2 bays & be done with it.16' span with 2x10 is pooh pooh. That needs to be addressed before any tiling happens. Can you sister on the outer sides of the bay with the mechanicals? Your deflection ratio is currently around L/270 :thumbdown
Once the joists are supported better, this is what I'd do:
Make sure the 1x4s are all screwed to the joists well.
Add a layer of 5/8" EGP screwed to the 1x4, NOT the joists.
Modified thinset
Ditra
Non modified thinset
Tile
You might get away with 1/2" EGP but I'd prefer 5/8".
got to do it right the first time, i'll use the 5/8, it will just make it under the door. is the thin Ditra ok. i'll deal with the ramps into the other rooms. i just hope they don't make me put up railings :laughing:
Thanks D.
unfortunitly i don't have the tools to do pic's or even sketches on this new fangled thing,i'm just a beginer. the wife has a picture phone but i probably need a wire to plug into this thing, if i even knew how to do it. anyway let me try to lay it out. walk in door,foyer 80" wide wall on right with opening to room.against that wall and looking straight ahead is the staircace, going up, with cellar stairs under. looking through subfloor joist run front to back, from door to stairs 6' 6" then they are boxed out for cellar stairs. stilllooking at stairs and through the floor, double joist on right under that wall,with another one next to that about 3/4" to the right, this one is just to keep the 16 oc going. the same thing occurs on the other side of stair opening, the double then one to the left, an inch away,between these doubles it is headed off for stairs with 2 joist about 6'6" long. now, next to the stairs is the 16' deep hallway into another room and the cellar door,this is where a main beam goes the width of the house, right to left, that the floor joist sit on. (note: behind this beam is the main air return ) so,next to the stairs is the open bay (save, some electric wires i can move) with the bridging, your still at the door,BTW. where this joist sits on the beam the back joist is overlaped inside this bay by quite a bit. thats where i was talking about the 2x4's for spacing, then the sister. next bay to the left holds the heat duct & can't be moved. and the next bay holds the air return. i hope this makes sence. :yawn: yeah, a picture is worth a thousand words.DD, I'll be honest, I'm not understanding how the joists are configured at your site. If you could post a pic you'd probably get a lot more replies about how to shore things up. That's what you really need to focus on.
If you could get L/360 or a bit better, you could skate by with 1/2" EGP. I'd definitely use the Ditra.
That was a good explanation, problem is I think only you understand it. :whistling
Back to that 16' span you spoke about. Are you sure the unsupported span of those joists is really 16'? I can't believe it. :no: It would also help if you could figure out the species and grade of the joists too. All wood is NOT created equally you know.
I recommend Ditra too. And. when you install the underlayment do NOT glue it, just fasten to the subfloor.
Jaz
