1 - 20 of 30 Posts
· Contractor of the Month
cut insul then move to next bigger slot and pull, stripper will last a very long time if the cutting edge isnt dragging on the copper
I don't think I've ever worn out the cutting edge before someone tries to use them as pliers to loosen a bolt. :laughing:
I carry a pair like this but really only use them to shear machine screws:
· Goin' Down in Flames....
Highwayman
Discussion Starter · #10 ·
Well, when you have 200 romex ends to terminate, using a knife would get a little tedious.
I always used standard straight romex strippers, and just fudged my way into the box. Then on a whim, I decided to try the bent nose. Found out they were discontinued, but they scrounged me 2 sets from other stores. Greatest thing since beer in a can. :thumbsup:
I can strip stranded as fast with a knife as I can with those strippers, solid core i'd risk ringing the wire and penciling is slower, but I bet I can strip with ***** about as fast as I can with wire strippers.
And don't loan them to someone to use for bolts.
Reactions: Red Adobe
1 - 20 of 30 Posts
