1 - 20 of 49 Posts
Not yet. I wanted to make sure I was right before I call the guy out on it. There may be more to it after I call him out on it. I’ll update and buy the beer when I win this bet. :laughing:
You'll win the bet hands down. Ken and Pete are good at having the NEC codes in digital form so they can post them. Me, not so much.
Hacks do this all the time but it's not correct anywhere in the US.
2011 NEC definition of concealed in article 100. The real question is answered somewhere in Article 314 somewhere.
Edit 314.29
Bubble stick operator
Don't bet yet... There's a code compliant no-box splice out there. However, the catch is that it has to be able to be fished out (i.e., accessible).
PCI
Isn't there an approved connection to do this per code?
It seems to me there is an approved connection you buy to splice a wire.
Cool product if it is legal. I'm in full conduit land. I'll wait for 480 and Speedy for a potential verdict. They can do Romex where they work and probably know the scoop on this product.
PCI
Understood, but the question was, "is a slice ever allowed".
I'm not declaring it up to code everywhere. I just know they exist.
My electrician said he would be more comfortable leaving a wire nutterd and taped splice before leaving this connection in the wall, ergo why I possess it.
I own stock in FotoMat!
As far as I can tell, they're legal under QAAV of the UL White Book.
NONMETALLIC-SHEATHED CABLE
INTERCONNECTORS (QAAV)
GENERAL
This category covers self-contained interconnectors employing pressure
cable connectors, insulation displacement or insulation piercing connectors
for splicing or tapping nonmetallic (NM) sheathed cable. These interconnectors are intended for use in exposed or concealed locations in accordance
with the following Articles of ANSI/NFPA 70, ‘‘National Electrical Code’’:
Article 545, Manufactured Buildings
Article 550, Mobile Homes, Manufactured Homes, and Mobile Home Parks
Article 551, Recreational Vehicles and Recreational Vehicle Parks
Article 334, Nonmetallic-Sheathed Cable: Types NM, NMC, and NMS (for
tap devices)
These devices have been investigated for equivalency to Type NM cable in
insulation and temperature rise, and for capability to withstand fault currents, vibration and mechanical shock that may occur during transport of
the units in which they are used.
PRODUCT MARKINGS
The devices are marked with the Listee’s name or identification, the catalog number or equivalent, and complete electrical ratings.
PRODUCT IDENTITY
One of the following product identities appears on the product:
N.M. Cable Interconnector
Nonmetallic-sheathed-cable Interconnector
Other product identities may be used as shown in the individual certifications.
ADDITIONAL INFORMATION
For additional information, see Electrical Equipment for Use in Ordinary
Locations (AALZ).
REQUIREMENTS
The basic requirements used to investigate products in this category are
contained in UL Subject 2256, ‘‘Outline of Investigation for Nonmetallic
Sheathed Cable Interconnects.’’
UL MARK
The Certification Mark of UL on the product or on the smallest unit container in which the product is packaged is the only method provided by UL
to identify products manufactured under its Certification and Follow-Up
Service. The Certification Mark for these products includes the UL symbol,
the words ‘‘CERTIFIED’’ and ‘‘SAFETY,’’ the geographic identifier(s), and a
file number.
Alternate UL Mark
UL MARK
The Listing Mark of UL on the product or on the smallest unit container
in which the product is packaged is the only method provided by UL to
identify products manufactured under its Listing and Follow-Up Service.
The Listing Mark for these products includes the UL symbol (as illustrated
in the Introduction of this Directory) together with the word ‘‘LISTED,’’ a
control number, and the product name ‘‘Nonmetallic Sheathed Cable Interconnector’’ (or ‘‘N.M. Cable Interconnector’’), or other appropriate product
name as shown in the individual Listings.
UL, in performing its functions in accordance with its objectives, does not
assume or undertake to discharge any responsibility of the manufacturer or
any other party. UL shall not incur any obligation or liability for any loss,
expense or damages, including incidental or consequential damages, arising
out of or in connection with the use, interpretation of, or reliance upon this
Guide Information.
PCI
Whenever you think you're making a crazy positive bet, pause, then pause, then back it down to what you can afford.
If it is in Denver you would loose. They adopted the 20124 NEC with no changes, Littleton/Highlands Ranch only has one amendment and it is administrative.
Most of my work is in the land of conduit so no splices outside an accessible point.
Tom
There was an episode of This Old House where they toured Ted Benson's timber frame shop where they build all the walls modularly and they used these non-metalic sheathed connectors to prewire the whole house. Not sure if it's applicable in your area, but I had never seen/heard of them before.
It's at 18:44 of the following video
https://youtu.be/l8ePHc5oALU?t=1123
I know they use them by the bucketful for manufactured housing. When they marry up two sections, there's connectors there to hook up the wiring.
And I've done plenty of service calls on said manufactured houses to know that it gets very expensive to refeed a circuit when the set-up crew doesn't get one put together right.
I pass on using them regardless of AHJ acceptability. The only time I would use them is in the lower level of a house build on flood-prone land where the house is literally on stilts and the lower level is sacrificial to flood water, tidal surges etc.
John the Builder
As far as I can tell, they're legal under QAAV of the UL White Book.with the following Articles of ANSI/NFPA 70, ‘‘National Electrical Code’’:
tap devices)
So, no-go on conventional stick-framed, or otherwise "site-built structures".
1 - 20 of 49 Posts
