What do you guys do when installing replacement windows? (I'm not talking about box inserts, I'm talking about whole window replacement)
Most older windows around here are wood frame with wood brickmoulds, and most of my customers want a PVC window that will reduce the amount of maintenance they have to perform.
Typically, when I install a window, I:
Does anyone do anything differently?
- Measure to make sure new window will fit (typically I order new window with the brickmould size 1/4" smaller than old brickmould, as it leaves 1/8" around for easy fit, doesn't disturb existing siding and it leaves a good line to caulk)
- Remove old window
- Prep & clean rough opening
- Measure & cut shims to fit under mullions/edges of window
- Dry fit new window
- Caulk the rough opening with clear silicone
- Install window & fasten
- Seal the window (all 4 sides) to the exterior siding/stucco etc with a thermoplastic rubber based caulk
- Insulate ouside edge with low expansion foam, finish insulating with pink, & finish interior
