1 - 20 of 32 Posts
Hello all. I have had a 28 degree clipped head strip nailer. I have 2 questions. One is it says to use wire weld strips. Can you use strips that are put together with paper? Also can a clipped head nailer shoot full round head nails?
I'm The BOSS
Just a tip for you.
Everything in life comes with instructions or directions.
We don't know the brand, model # or type of nails your messing with.
OH, WAIT. there is one thing in life that DOESN"T come with instructions.
.woman
I can't see a legitimate reason why you can't use paper bound nail strips. I bet the brand of gun you only makes wire collated nails, that's the only reason I can see they would recommend that.
Not even once.
Mr Wizard has an experiment for you though:
Put the paper collated nails in your strip framing nailer and pull the trigger.
Do you have a hypothesis as to what may happen?
Let me give you another important variable in this experiment.
The paper collated nails are set at 30 degrees. Knowing this would you still think it will fire?
I'll tell you exactly what will happen.
The driver blade on your stick nailer will sheer the top front of the head off of the nail, and the driver blade will become stuck between the nail throat port and the shank of the nail.
More than likely, you will drive the nail halfway though the bottom part of the magazine sleeve.
Get out the Allen wrenches now, and a pair of side cutters, and a long thin screw driver.
( and unplug the gun from the air hose before you start working to clear that jamb).
OP, for what it's worth .... It's a good question.
They make 28 degree clipped head framing nails for strip\stick nailers.
They do make clipped head framing nailers that shoot full head nails as well as clipped.
Love me some Concrete
Brand and model #, look up info on manu web site. That is the only way you will really know.
I would not do it, I have 2 different types of nailers and the nails are not interchangable, I would not try either, not worth it.
1 - 20 of 32 Posts
