that is the best lock I've ever seen. use em on all trailers.i have one of these
http://www.northerntool.com/shop/tools/product_200172024_200172024
equals easy to cutLong harp padlock.
Tom
I bet I could get through any kind of trailer lock in under 3 mins. Locks only stop an honest thief.equals easy to cut
They need to rate them like safes, in the amount of time a pro can crack themI cut my coupler lock of in less than 60 seconds. Its also meant to be one of the better ones. That mega hitch lock is a nice bit of kit. I'm sure that's got to be up in the 5min range to remove.
Some do. There was a system in the UK thst gave them ratings for insurance company's. they then told you what type of lock grade you needed to use as a minimum on that item. My jetski needed a $200 5ft chain and a $150 padlock. It had a crazy looking key and it was impossible to get to the lock shackle with a cutter. You would have had to cut through the whole lock.jlsconstruction said:They need to rate them like safes, in the amount of time a pro can crack them
That's the only reason I lock anything is so insurence covers it when it gets stolenSome do. There was a system in the UK thst gave them ratings for insurance company's. they then told you what type of lock grade you needed to use as a minimum on that item. My jetski needed a $200 5ft chain and a $150 padlock. It had a crazy looking key and it was impossible to get to the lock shackle with a cutter. You would have had to cut through the whole lock.
Long harp padlock.
Tom
If they really want the traier a cordless grinder will make short work of any lock. They're only there to keep the honest, honest.equals easy to cut
