I just looked at a pergola job I did 5 years ago and witnessed a condition I been seeing more of the past 5 years than in my previous 40 years.
Wood 5-14 years old rotting, and not in any of the areas an experienced carpenter would expect to see. Exterior wood window sills with completly unnoticable rot in the middle of the sill not where casings meet sill (typical). Might notice a slight paint blister or nothing, but poke with a finger and through it goes, no logical or possible explanation of why water penetrated.
6x6 best quality Doug fir posts sitting on typical metal post brackets.
Based with 1x6 and cap moulding, no wood touching grade on a paver patio, rotting , pushed a thin screwdriver 4" into it 2 1/2" above base cap. Doesn't make sense
The window job which was Marvin I installed in 1998, allegedly used a wood preservative (supplied to them by PP&G) to treat the woods from which the windows were made actually caused the rot. Thier were lawsuits and so on.
I am beginning to see some common issues with this rot in un-expected areas, a fair amount of what looks like mildew on same job area but not always seen at specific rotted area, sometimes no visible signs at all, sometimes what looks like paint blister.
I am wondering if anyone else is witnessing similar what appears to be unexplained rotting wood.
I am beginning to suspect these newer acrylic and latex paints are not only not doing thier intended job of protecting the wood from moisture but wicking and or trapping it ???.
I have been at this and seen enough over the years to explain most.
Lately I am puzzeled with what I am seeing, it's not making sense.
I also heard possibly newer growth trees used for making this wood from is a possibility. Been around myself long enough to have noticed the decline in lumber quality. ???
Please share any similar experiences or possible explanations.
I also believe in Good quality "oil base primers" for all exterior wood to be painted.
I am searching for others who are puzzeled by this and thier thoughts.
Thanks and looking forward to any responses or thoughts on this topic>
