1 - 20 of 136 Posts
I use a synthetic underlayment, goes down faster, stays on better and dries in the roof eliminating the need to tarp.
Is the use of underlayment still an item of debate? I thought that was settled ten years ago. People were sure stupid in the nineties.
Project Manager HFH..
The code here does not call out for felt or underlayment, hence the reason for this question.
Thanks for such an answer, it was very insightful. :thumbsup:
You can put shingles or tiles right on the sheathing where you live?:blink:
Yes, some are telling me no felt/underlayment is fine, others say the thought alone is crazy. I am trying to wade through the fact/ficton. Thanks for the help.
In other words- can shingles be applied to bare wood?
The shingle brand makes it sound like an option as well.
GAF Timberlines.
I assume from his screen name he's from Maine where I live. Except for our major cities, you can do almost whatever you feel like. The few simple roofs I have done, they have felt.
I'm not positive since I really don't educate myself on roofing but I thought if you do not put felt or something under, then you void any warranty. I might be full of ****, that's what I was told.
Actually it depends upon what your code says but if your governing authority uses the 2006 irc it depends on what "roofing" you are installing. The irc says under metal sheet roofing that you must follow the manufacturers installation recommendations. If the manufacturer says the metal is to be installed over felt...then it must be installed over felt by code.
"conflicting reports" are irrelevent.
JumboJack for president!
ya it is not a requirement here either. A lot of new homes don't have it anyhow. Especially in the rural areas. In fact some roofers i have used in the past said they only use felt to help the guy doing the tear off in the future. it doesn't stick to the sheathing.
I believe I saw you question on another forum (related to water) and posted my response there. If you're going to lay shingles, why not put felt or some sort of underlayment down? For what it cost and the time it takes to install, just do it. Something of such a small magnitude isn't worth the time to question.
1 - 20 of 136 Posts
