1 - 20 of 23 Posts
Hi Folks,
I'm looking for a good quality white paint. I've found in my experiences that most white paint almost always requires several coats. I typically use white to paint white primed moldings and even sherwin Williams best quality enamel to requires me to roll down at least 3 coats.
Any suggestions on a brand that would cover well and look good with only 2 coats?
Thanks,
Al
Hair Splitter
I'm one coat on primed baseboards, doors and crown with pro classic semi gloss brushed on. I do 2 just to make sure there's a thick enough layer of final on there but as long as your primer is white it should me at a maximum a 2 coat.
Same here but with dutch boy semi-gloss ultra white. Prime and two coats to ensure a good to coat. I don't add any pigment to my trim paint but do add two drops of blue to me ceiling white for coverage.
Every now and then poster
Start with a good quality primer. For trim I like using either Promar 200 Alkyd modified as a finish or proclassic.
Plus one, I have been using 200 on trim for years. Great stuff!
Hair Splitter
Dutch Boy ?
Yep! I cannot stand Dutchboy. I am a Ben Moore guy, but the SemiGloss UtraWhite is awesome. Goes on smooth, finishes smooth and has really good coverage and hide.
I was shocked as you when a painter buddy recommended it. I used it several times in my own home with my kids as a good test for durability. Washes awesome and lasts forever. I used it on my kitchen cabinets nearly 6 years ago and they look like I just did them.
Hair Splitter
That's what my current painter likes. If I hire him to do the job that's what he uses. I may try it on the next one.
Hair Splitter
I'm not a Glidden guy, but their Gripper primer is slicker than snot on a glass door knob. It's about all I use anymore.
Me neither, but started using their Ultra Hide on rental units and gotta say it's pretty decent paint.
I like SW for coverage, but they've just gotten too pricey. I've started using Valspar Signature this last year and have been pretty pleased with it. I'll have to give the Glidden a look see on a non-critical project. Thanks for the heads up on the Ultra Hide!
semi-skilled laborer
We used to use the Ultra Hide flat on production houses. Nice coverage and touches up well. The guy I worked for at the time eventually switched to SW Cashmere which I hated. Didn't touch up as well and they could never break down the formula from a five to a gallon, so if I needed a gallon to touch up something I had to get a 5 or it wouldn't match at all.
Discussion Starter · #17 ·
Hmmm maybe I'm doing something wrong? This is exactly what I've been using to paint pre-primed based from the depot. I find one coat seems to be a tad translucent and I need 3 coats to look superior. Maybe I'm just being a little too picky? Or maybe I should prime over the primer with a slightly tinted primer? I typically use a 4" "whizz" type roller with what I think is a 3/8 nap...not sure ill have to check the package to confirm nap size. Speaking of nap...:::yawn::: LOL
Has anyone had experience spraying a white in a HVLP sprayer? I experimented last night with the SW pro-classic but "thinned" it 50% (8 oz paint to 4 oz. H2O) which id rather not I was just afraid the latex would be too thick on its own to go thru the gun. Didn't look too too bad...but it was more or less just an experiment!
Thanks
Thanks
A roller puts it on thin so that's one issue. I have found I get better results with brushing it on. It seems to level out like glass. You also need to use a decent primer. I now use the preprite as the premium wall and wood was way too thick. I had much worse results with the more expensive primer. 1 coat of preprite and 2 coats of final pro classic should give you a very nice finish. If I'm happy with it then most others should be as I'm a anal ass about finish quality.
1 - 20 of 23 Posts
