1 - 20 of 27 Posts
Been using USG Sheetrock Brand 20 Minute Lightweight Setting Compound for years only because that's what everyone is selling. Now I see other companies are getting into the mix. I see HomeDepot has "Rapid Set" One Pass 20 min, and Lowes has Pro Form 20 min.compound Tried a bag of the HD stuff(Rapid Set). It seems to work alright, though its not a lightweight compound its a little stiff working. It sets fast and dries moisture free a little faster than the Sheetrock brand. Its kinda dark colored when dry, but thats not really a problem. I want to try the ProForm stuff from Lowes but havent had the chance to get any yet. I dont usually do any large scale drywall taping, mostly only repairs to drywall(re-taping loose old tape joints) and plaster repairs with it. Any opinions on the different brands good or bad?
Want to play a game?
USG is all that is available to me so that is what I use. Cant say too much about the others you mentioned as I have not used them.
One brand I always liked was Hamiltons. Always very smooth but I never felt it cured like USG. What I mean is if you got a 5 min bag the mix always took a little longer then if you were to get a 5 minute bag of USG. I was always willing to put up with it because of how smooth the mix was.
Repair & Renovation
My supplier carrys pro form. My homedepot has sheetrock brand. I feel the pro form sets quicker than sheetrock brand. But it's comparing apples to apples.
I noticed home depot stocks a product called rapid set 20. What's the advantages .. I noticed it was mold resistaint ..
I go with the Pro-form quick set lite. I used the sheetrock/USG 20 for years. Both are good. But the Pro-form is cheaper, Smoother and not only finishes and sands better, but it receives the ready mix compounds better. I like topping with the lite and mid-weight compounds. The quick set is a better option. I was a USG die-hard. Today they are just over priced. Though I do like their ultra light.
I use plaster of Paris mixed with hot water and bondo, over and under both paper and mesh tape, on not just the seams but the flats too. Anything else is shear hackery..
Not sure if you're kidding or serious. How quick does the Plaster mix set up for you? What's your top coat?
I mostly use 5 and 20 easysand, green lid for top (or top with 5 or 20 for small stuff).
Discussion Starter · #10 · (Edited)
Bondo, plaster of paris, with hot water sounds like a good mix.:eek:do you use the blue hardener or the red stuff? Actually, all kidding aside.......... I have used Bondo in a pinch for filling medium sized holes in walls from old toggle bolts and molly bolts when I needed really fast drying time. Next time I get to Lowes I'm gonna pick up a bag of ProForm and try it.
Home Repairs
Proform 5 & 20 minute for smaller texture repairs. (knockdown, popcorn, and plaster). ProForm does not setup hard and brittle like USG and it loves to be tooled down with a wet sponge and 5" or 6" knife. It all gets done with a single coat. All you have to do it keep lathering the setup mud and tool the lather into the edges and low spots. You can immediatly apply any texture you like over the mud as soon as it sets again and they can dry in together. I have been doing this for about 12 years. I am surprised that most drywallers dont use this technique. I hear all the time from other finishers that 5 & 20 minute is mud useless. I make a nice portion of my income by using it. :)
Home Repairs
I won't knock USG as they make a lot of great products. But the ProForm hot mud is much more forgiving to use, and you can really play with it as it sets........even afterwards.
Home Repairs
Proform 5 minute with clean cool tap water is really a 15 minute mud. With hot water....about 5-10.
Easysand 210, cause ya get like 3.5 hours to work with it, ha. Not really, but I did buy it on accident once, then I saw the bag and was like wtf?
Discussion Starter · #17 ·
I do that alot with the 20 min. cold water slows it down and hot water speeds it up. Its especially fast setting on a 90 degree summer day, even with cold water. Thats when I sometimes switch to the 45 min just to keep my sanity.
I did that once too. 10 yrs. ago. Just saw the 2 on the bag, thought it was 20. :laughing: Have never seen it since.
I use all National Gypsum products 99% of the time. (Pro Form)
Just ran a bag of Easy Sand yesterday. I'll have to say it worked real nice. Was out of stock on my normal brand and nearby big box store saved a lot of driving time.
We all get used to one brand and using another can be challenging at times but they are all good.
1 - 20 of 27 Posts
