When it comes to replacing a metal framed window in a brick veneer house what's your typical strategy for the replacement window? Let's assume the old metal framed window is a new construction metal finned one.
Do you typically plan on cutting out the entire frame of the old window and install a new replacement to fit the old brick openning?
Do you remove the removal window sections and install the new inside the old frame and trim inside and outside?
