1 - 7 of 7 Posts
President
I need to fill an area, 50x70 raised 3' then put a 6" concrete floor measuring 40x60 on top of it. Must be atleast 3' per town code.
Crushed stone... What type of crushed stone, and how much will I need? Yards + tonnage
I always used 3/4" Gray, crushed stone. I've seen it called a bunch of different names.
And there's tons of calculators on the web to give you the "how much".
Also, I assume you're having it delivered, they'll tell you how much you need too.
President
It needs to be raised 3' above surrounding grade. Pesky flood plain stuff :whistling
I thought about clay, and other things such as hard fill, but that can get ugly... So I figured 3' of stone would also make my 6" pad stronger...
I know there's calculators online, but, I don't know whack stone size I should go with...
Just shy of 400 cy like griz said. I get just under 800 ton of crushed stone, road base what ever you call it in your area. Stone could get pretty expensive just to run fill.
Find a close dirt job and see if they are heavy. They might load it and haul if you just pay the trucking?
1 - 7 of 7 Posts
