What to do about this ridiculously placed header
1.5K views 10 replies 6 participants last post by  TWCW
Alright so I’m doing some remodeling and expanding the bathroom that was hardly a bathroom. For the sake of not having a 20 paragraph post I’ll get right to it. I need to rough out a door on this wall, I remove the garbage 1/4” osb to find a random header. The rough opening needs to be 32” x 80” for the door I’m installing and I really would prefer not to make it a hobbit door.
So here’s what I would like to do, I’d like to set some jack studs doubled up where my rough opening would be and just cut out that entire section of header then make a new header above the door kinda like normal but the header I install for the door would be attached to the cripple studs above the existing header.
or
should I set jack studs to support the existing header, cut the header and run king studs then new jacks to support my new header?
View pics
it appears this room has been remodeled a couple times in the past hints the cluster of studs next to the double door header that I’m converting to a single
#11 ·
Okay so I pulled more of the osb off of the wall so you guys can see more of what I’m dealing with.
View pics
iCloud Photos - Apple iCloud
Idk what this header was for maybe like a bay window or something it’s 74” w and 72” h.
That turned 2x4 is doing absolutely nothing it’s not touching the subfloor. It was put in just so whoever built the nightmare of a wall that I removed had something to nail to other than just the header. I think the air handler was installed after this previous renovation because they notched out the backside of the header to make a spot for the drain lines. On the other side is the drain lines for the air handler in the attic. The pipes are another obstacle I have to overcome because they protrude out of the subfloor about 2” on what will be the inside of the bathroom. I already have a plan for that.
Really I’m just looking for other professional opinions on how to go about cutting this header because I keep second guessing myself. Or I could just say screw it and cut a door down to fit the 72” opening under the header but I’m 6’1” and it kinda pisses me off that I build such nice things for other people but have to deal with a hobbit door in my house because I’m just not 100% sure on what route to take.
