What tile project are you working on?
618K views 4.1K replies 216 participants last post by  TileMarbleGranite
It's been a little dead hereabouts lately, so I thought I would try and liven things up a little.
Post some pics of your current tile projects in progress. The good, the bad, and the ugly.
#2,877 ·
OSB is prone to edge swelling.
If it does get wet it can and will expand. I've seen plywood soaked around a toilet and once it dried out it was fine. Never happen with OSB. It will swell and fall apart.
It's also just a personal preference. I don't like working with it. And even though I know it has the same strength as plywood it just doesn't feel solid.
#2,894 ·
I Demolished this little gem the last couple of days. It was a Homeowner/Handyman special built in 2008.
First off the pan was REINFORCED CONCRETE and 3 Inches thick at the Drain, 7 Inches at the thickest point.
He Installed a CPE liner all the way 10 feet and up the liner on the wall first, the a wall/floor splice then the floor liner. The liner was glued to 1/2" Plywood and had 1/2" CBU Screwed over the top of it. Bonuse the liner was over the weep holes.
The amount of overkill with PL and Silicone was useless because it was in all the wrong places.
My favorite was all the blocking he added.
This post has been deleted
#2,908 ·
I think it looks great!
Some will blast for the running bond but I like it. Nice and clean looking.
Things that I would have done a bit different, but I wouldn't consider wrong would be centering the niche up and down.
I also don't like bullnose on the inside of the niche, but if you want a clean look, that's one way to do it. And it's really not the use of the bullnose, but how hard it is to get the corners to look nice. I usually just install a pencil around the perimeter if I can get away with it and the clean design look.
#2,909 ·
Thanks Rob! I will admit that I goofed my layout of the niche because I did want it centered better height wise.
I really like the pencil edging you posted. With this tile the only choice was bullnose. I like a Schluter profile too but the client did not like the look of that.
