What tile project are you working on?
620K views 4.1K replies 216 participants last post by  TileMarbleGranite
It's been a little dead hereabouts lately, so I thought I would try and liven things up a little.
Post some pics of your current tile projects in progress. The good, the bad, and the ugly.
#2,056 ·
ohiohomedoctor said:
John, as good as the tile work is the drywall patch is needing some attention. :jester:
Lol
I suspected some heat over that pass!
I'm on it. I'm going to sand the edges and give it the first of hopefully two top costs.
Had some cracking on my old work that I Need to fix up as well. Looks like the glass door hardware stressed the top corner of the entry way.
JW
#2,058 ·
Well it ain't gonna win any awards but I'm happy with it. Laid the heated floor mat and buried it in Novoplane, it worked well but still left hills and valleys up to 1/8" that I had to compensate for.
Did all my cuts with a Sigma 2B3 and a grinder. Found some Ultraflex LFT, used LASH from home depot to, 1/2x1/2 notch trowel.
Only problem is I got more thinset on the face of the tiles than the back...got a lot of scraping tomorrow.:laughing:
Couldn't have done it without all the helpful advice from Angus...cheque is in the mail!
PS I learned that setting tiles sucks, I ruined my pants and my fingers and knees are killing me.
#2,063 ·
Looks good Inner10 !:thumbup:
I fail to mention those things and it seems Angus did also!
Thank you!
It is far from perfect though...I admit looking back the wonkyness of the floor was my demise. I should have marked all the high and low spots and started with the high spot and went out from there and keeping everything perfectly level.
The LASH system sure doesn't level anything (much like the instructions say). There are some places where the tiles are out of level just to avoid lippage...and some areas where there is slight lippage to compensate for a less than perfectly level floor.
Next time if I were to use the LASH clips I think I would mix the thinset a little thinner and use the bigger U notch trowel like Angus suggested instead of the 1/2x1/2. I found once the tile was dropped it was suctioned so strongly to the floor it was almost impossible to squish it down...and the 1/16" grout lines don't let any excess squirt out...so I did a lot of prying up the tiles and removing excess schmaltz with my margin trowel.
I took for granted how "self leveling" self leveling compound is...I also took for granted how much "workability" you have with thinset; you can't just muscle the tile into place.
I'l take some pictures of the errors when I get the mountain of dried thinset off the tops of them. :laughing:
Plus how do you guys keep your hands clean from mucking up the tiles? I had a grouting sponge, 5 rags and 2 buckets of water and I was constantly washing hands, switching rags, washing the sponge, wiping the edges of the tiles, cleaning the grount joints with a putty knife, wiping the tiles down (which didn't work around the LASH wedges) and still I made a massive mess.
#2,064 ·
I should add...my girlfriend gets home from work and looks at the tiles...then she gets her nose about 6" from one of the slightly high corners and picks at it with her finger and says "so how do we fix this?"
:censored:
We don't!
...I think I was expecting more of a "thank you" or "good job"...not in this fvcking house.:laughing:
