What tile project are you working on?
2 reading
618K views 4.1K replies 216 participants last post by  TileMarbleGranite
It's been a little dead hereabouts lately, so I thought I would try and liven things up a little.
Post some pics of your current tile projects in progress. The good, the bad, and the ugly.
#2,027 ·
Busy week this week - lots of odds and sodds.
Grouted the niche finally with the side lit shelf.
Trying to figure out how to finish this floating bench.
Working on testing my Hydro Ban drain.
JW
#2,029 ·
Why is the foundation coated with red paint below the stone? Is that Denshield and redguard up above the new work?
I wonder how hard this bench will set up with just a few self tapping screws and tie wire as a reinforcement system for a bag of Mapecem Fast Setting Pre-Mixed Screed Mortar?
I put about half my weight on the wire prior to forming the bottom with some scrap poly and drywall off cuts. A little more work and this bench will be ready for tile.
JW
#2,030 ·
JW
I really want to do one of those shelves. Have you created install instructions on those yet?
#2,031 ·
Seeing John's "propped up with what's lying around pic" reminded me of this one ... Some days we literally could only do 2 tiles in this massive shower with 3 large niches. I didn't design this thing ... Just had to build the bugger ;-)
#2,033 ·
Its Redguard,not paint.Stone isnt to the bottom yet
No,its DuRock NextGen and see above answer. Stone will go up there also.
#2,037 ·
JW
That seems like a hard way to do it. Granted, you could get a 700 lb guy on there with no problem. But why not just regular framing since it could be attached to each adjacent wall?
Nice stone work Evan. It is nice do that every now and again. Wouldn't want to do that everyday though.
#2,039 ·
We haven't put the required coats on the top area yet.
Cause you got nothin.
Bare in mind I don't know my mouth from my arsehole when it comes to exterior finishing but my basic knowledge tells me in Ontario that wouldn't fly. Exterior finishing have to breath, if you want a water tight finish like stucco you have to put foam with vented channels on first.
#2,045 ·
Evan1968 said:
This is a small section of the front of the house. The other 3 sides of the foundation are above grade. House breathes just fine.
Stop being a plumber and become a renovator and i might.
Edit
#2,051 ·
JohnFRWhipple said:
Installed some under cabinet lighting in this bathroom.
Used a brass flat panel strip for a Heat Sink and just double sided tape to install.
Keep the LED strip back 6" from the face of the drawers.
Cool idea. May use that one for my own master.
#2,053 ·
ohiohomedoctor said:
Why do you need a heat sink with leds?
I believe it's so they last longer and don't over heat.
Some Mapeband and reinforcing fabric in the floating bench today
Installed a 3/4" L bracket as a heat sink for this cabinet on the same job
You can see the light through the window
Same warm led lights for kick and electric mirror install. I'm loving this FibaFuse drywall paperless tape
